Injectors
Injectors
I need help. I know RSX-S injectors work for our cars, but would i be able to make 450 DSM injectors work? If so what would i have to do to make it work. Any suggestions would work because I am going to turbo before I go back to school and need to know.
If SRT-4 injectors fit, how would i wire it up?
If i do use a resistor box with the dsm injectors, would i wire it up the same way i would with a 5th or 6th gen civic?
my understanding is the srt-4 injectors will fit BARELY(just need injector clips), anything bigger requires custom work with TPS/throttle body/fuel rail clearance issue
since SRT-4 injectors fit, which year will fit right? From my understanding the 05 srt-4 injectors would be an upgrade for the 03 srt-4. Since srt-4 injectors fit, how come there aren't anyone talking about using them for their turbo setup?
Because if you are positively right about the injectors fitting I will put the order in on them.
I just need to know how i can have a good fuel system for my turbo setup, but also save enough money for school.
Any help please.
Any help please.
Any help please.
Any help please.
I am just going for 6 PSI at the most, I am on a budget and I basically have everything except for the injectors. Without them I can't finish my project this summer. And I am desperatly looking for answers. RSX injectors are too expensive. Theres a guy on ebay that will sell SRT-4 injectors for 70. I just need the clips.
7thgen Power Maker
So I will go with the SRT-4 injectors. Wish me luck i hope it turns our fine.
Ok what do you mean by standard RC clips?
Nevermind that question it was stupid, hopefully this question isn't stupid. How will i wire the clips on to my car?
please excuse me I am new to this stuff.
Last edited by BCCentaur3; Jul 10, 2006 at 10:35 PM. Reason: Automerged Doublepost
your talking about 80 each, I went to the Acura dealership they told me 700 for a set, then i went to Checkers they said 310 without the core, which i don't have. I am saying 70 for a set of srt-4 injectors. I can't turn that down. Especially if they fit. Just gotta figure out how to wire them up.
I can't let the last and final obstacle mess me up from my 3 years of planning. All i need are injectors and I am done.
Last edited by BCCentaur3; Jul 10, 2006 at 11:03 PM. Reason: Automerged Doublepost
I has dsm 450s with the resistor box. Cutting them back at idle they really work like crap even with the AEM. Ill be hopefully switching back to RCs sometime in the near future. The dsms probably would be a biatch to fit on a stock intake manifold config.
7thgen Power Maker
Are you sure it is not from the cam and compressor surge?
srt-4 injectors and v-afc2
for my fuel option i went with v-afc2 and rsx-s injectors.... i found out later it was a mistake.... the rsx-s injectors and emanage is the best combo....
but what about srt-4 injectors and v-afc2????
Don't run srt-4 injectors unless you get the ems. You will run extremely rich and you won't like the results. The srt4 injectors also take a lot of fuel pressure. I even had a little trouble with them on the ems but we figured it all out. The fit is extremely tight. I had to take off my tb to install them and then the tps is hitting the fuel rail thats how tight they fit.
yeah, if they are that big of a bitch then **** them.... emanage then ha?
i just need the support tool? i mean the usb cable that connect to emanage, i got the software on my laptop already!!
Bruce2
Sep 21, 2015 08:01 PM
