stock sterio connected to subs.
yea just wondering if it is possible to connect your stock sterio to some subs. i really want to do this cuz i really dont want a new deck. does any one have a wiring diagram for this thing.
Yes its possible. you just tap into the rear speaker wires to get the signal instead of running rca's from the head unit to the amp. And its been awhile since i've messed with car audio, but i'm pretty sure you don't need to run a remote wire if youre getting the signal from the rear speakers instead of rca's. then just power and ground, and you should be set.
4 cyllinders are good but 5 is better!
Yes it's possible just as the guy above me noted but be aware that the bass will be crappy because you are basically amplifing a equalized signal from the stock head unit. Stock stereos have non-defeatable eq's built into them so that you do not blow the crappy factory speakers. For example, when you turn the volume up on the stock unit, your bass volume will decrease. That pretty much defies the point of a system unless you plan to drive around with the volume barely up. IMO trash the stock unit and get an aftermarket one with pre-amp outputs. The sound quality will be loads better and you can individually adjust your subwoofer level without affecting the rest of the speakers.
7thgens official a$$hole
just go get a high to low siganl converter from best buy or something and use that. easy to install and it works.
plus this thread belongs in ICE its been covered about 136189 times.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
jru27
Jun 19, 2015 03:51 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
htowncivicEX
Nov 13, 2001 04:30 PM
