Throttle Cable Adjustment *HELP*
I wanted to do the adjustment that everyone else is doing but when I did the research and even got the help from peep'z, I opened the hood and looked....Gave up basically.. Anyone got the patience and willing to help me out would be appreciated..
Thanks
[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Thanks
i posted better pics of it before.. search for throttle cable, it should be there..
but if you wanna know, its behind the airbox thingy mababer.. the one behind the valve cover if your looking from the front of the vehicle. and its to the right, and behind the airbox or watever its called..
aw nuts, nm the post.. forgot my @home webspace got deleted.. sorry but if you need it, i'll take pics for ya
So it's not worth it then huh? Well any pics would help and if it does help any at all peepz let me know...
[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG] I'm bigger than you.
Don't waste your time with it, the mod that I would suggest though is shaving the ULEV sticker on the drivers side window....apparently some on the board here claim atleast 20 horsies!!!
Just find the cable connected to the rear of the throttle body. Push on the round gold colored thing and you will quickly identify the throttle cable. Now, loosen the nut on the driver's side of the cable. Lift the cable out of the little bracket. Then, give the nut on the left or passenger side of the cable and few spins, put back into bracket and tighten up the drivers nut snug. Check to see how much slack you took out of the cable.
I think it is worth while to do it. The cable has so much slack stock and I definately noticed that when I first got the car. It just makes the pedal and little more sensitive and adds about 50 hp.
[IMG]i/expressions/laugh2.gif[/IMG] Listen man all it does is make your throttle more sensitive. I did it on mine and love it. Others hate it, its your desision but once you do it, it is very hard to get it back in the same place....
Peace
Peace
Nalmonte
Jun 3, 2015 11:01 AM
Shakzhussain
May 17, 2015 12:03 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
2002, adjustment, adjustments, bracket, cable, civic, gas, honda, location, make, nut, pedal, sensitive, throttle, troubleshoot
