my question for the smart people who KNOW
so my stock exhaust has been chillin outside for 6ish months... i dunno what may be living in that thing but one day I may want to put it back on my car... so onto the question: can I, or HOW can I, "clean" out the exhaust?
can i use water, let it dry in the sun and cover both ends of the exhaust and store it?
or, does that idea sound rediculous? I will let it dry for a while now, don't get me wrong.
if I'm a moron then I ask... HOW do I clean out my exhaust? thanks fellas and ladies
it shouldn't matter. just use a vacuum to blow air through it or something. as long as there's nothing flammable, it should all get blown out or burnt with the exhaust gases.
exactly. you could wash it out if you wanted to, but i see no real reason too. there's probably nothing in it, aside from some dust, pollen, etc.
if water or moisture got into the exhaust while it sitting still for so long, it could very well have formed rust on the baffles inside the muffler.
if definite that there's no rust, not much harm in flushing it out like you said. make sure all the water comes out - use a good vacuum or you'll have to shake & turn the muffler A LOT because the inside is like a maze. a few leftover drops wont matter because it will vaporize after back onto the car.
**BUT this does not mean all you other drivers should jam a water hose down your cars tail pipe**
also you want to make sure nothing else got in there. solid stuff like pebbles will make rattling noises. leaves or small animals will give off a burining smell.
edit: i type too slow
gearbox summed it up
gearbox summed it up Last edited by XxSoVeReiGNxX; Jul 1, 2006 at 07:28 PM.
SidCivic
Nov 24, 2015 08:36 AM
alxz310
Jul 30, 2015 12:18 PM
roger t
Jun 22, 2015 07:25 PM
