BIG RSX Injector problem...
Old Jun 30, 2006
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey guys, wondering if someone can help me out.
I've installed this rail with RSX injectors plenty of times before, but for some reason I can't get it to work this time.
Whenever I prime the system, fuel shoots out of the last injector, or the first injector sometimes.
What am I doing wrong?
I believe the fuel is coming out of where the injector meets the rail, not where the injector meets the injector plate...help!!
Old Jun 30, 2006
Michalo187's Avatar
Abortion Survivor
are you sure they are pushed in far enough? And is the o-ring still there to seal them? its probably something little like that. Make sure everything looks correct and that they are tightened down enough.
Old Jul 1, 2006
tfnaaf's Avatar
BLDNPSI Mod
bent rail?
Old Jul 1, 2006
ajhdragon's Avatar
7thgens official a$$hole
im going with leaky o-ring
Old Jul 1, 2006
skipbarber's Avatar
those o-rings dont like to be reused more than once or twice. id pick up a set of new rings.
Old Jul 1, 2006
TheSmuggler's Avatar
Degraded o-ring ftl =*(
Old Jul 1, 2006
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
make a run to napa and pick up some more o-rings...i bet that is your problem
Old Jul 1, 2006
ajhdragon's Avatar
can't get the o-rings at napa, only a dealer item or atelast ive found here. but a tip got o toyata and get the celica injector o-rings, thier alot cheaper than the $10.50 an o-ring from honda.
Old Jul 4, 2006
Hwoody77's Avatar
Well luckily my brother had an O-ring set so I was able to replace them on the spot.
But yea, the O-rings were the problem...thanks a lot guys!
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
Luluharp
Sep 27, 2015 11:56 AM
anubis62
Sep 27, 2015 12:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
