BIG RSX Injector problem...
Hey guys, wondering if someone can help me out.
I've installed this rail with RSX injectors plenty of times before, but for some reason I can't get it to work this time.
Whenever I prime the system, fuel shoots out of the last injector, or the first injector sometimes.
What am I doing wrong?
I believe the fuel is coming out of where the injector meets the rail, not where the injector meets the injector plate...help!!
are you sure they are pushed in far enough? And is the o-ring still there to seal them? its probably something little like that. Make sure everything looks correct and that they are tightened down enough.
7thgens official a$$hole
can't get the o-rings at napa, only a dealer item or atelast ive found here. but a tip got o toyata and get the celica injector o-rings, thier alot cheaper than the $10.50 an o-ring from honda.
ricer_em2
May 11, 2016 08:09 PM
