Spring Installation
Old Jun 23, 2006
99lude_06's Avatar
99lude_06 is an unknown quantity at this point
Spring Installation
Hey guys, I did a search for "spring" and "spring installation" and "suspension" and nothing relevant came up.
Are there any guides here or someone that can help with lowering spring installation on 04 Civic coupe? The front struts look all connected and stuff and I can't get those out like the rears.
I downloaded that manual but there's no way to get to the suspension (it's grey'ed out).
Any help? Any guides I can follow?
Old Jun 23, 2006
oi2325's Avatar
oi2325 is an unknown quantity at this point
What kind of struts do you have?
NM^ What knid of springs do you have. Do you have a spring Compressor
take out the 2 bolts from the stearing knuckle, take off the tie rod ends(nut&seperate from knuckle), remove the brake line from the knuckle (nut). Then all you should have is the 3 bolts on top. when you have the thing out, mark which side faced outwards on the top and bottom so you can try and line it up later. Compress and while compressed use an impact to remove the bastard nut on the top middle. Remove and reinstall the opposite way.
Old Jun 23, 2006
Rennen's Avatar
New Mod on the Block
http://www.7thgencivic.com/forums/sh...ad.php?t=86545
rep?
Old Jun 23, 2006
oi2325's Avatar
Its not that hard if you get a manual. I just skipped half the steps that didnt mean anything
Old Jun 26, 2006
stephenb80's Avatar
stephenb80 is an unknown quantity at this point
its easy just take off the strut and put the new spring on it.
Old Jun 27, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
That's it....you've done it...
Mex has easy to follow linked by Rennen...
Old Jun 27, 2006
dj02's Avatar
and theres been many diys posted as well. you just need to do a better search.
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
