Need help on neon wiring in trunk! Won't turn on when it's supposed to!
Old Mar 4, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
So I'm wiring my neon in my trunk and I was running the power off of the trunk light, figuring that when i open the trunk, the trunk light AND neon go on at the same time. Well it didn't come on when I opened the trunk, and I couldn't figure out what was up. So I look in when my trunk is closed and theres the neon, glowing like it should be. So i pop the trunk again to see if it works and it shuts off. So basically it's working the OPPISITE way it should. What'd I do wrong?
Old Mar 4, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
ummm..... maybe try swaping the wires...... you said its on when the trunk is closed, and off when its open... maybe you awnsered your own question???
Old Mar 4, 2002
VNlilMAN's Avatar
The Standard One
ya hook up the + on the neon wire to the other wire thats on the trunk light.
Old Mar 4, 2002
the neon i bought only has a power and ground wire and thats it. so i just tagged them right on to the power and ground that runs to the trunk light. i dont get whats up, ive tried different grounds, differnt amp fuses, its weird.
Old Mar 4, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
You prolly got a bad tube! it came with a cig lighter attachement right!? try hooking up to other stuff to see if it works! Get a dc test light or use a multitester or a volitmeter- and test your light wires!or just start touch each of the two trunk wires to metal to see which one is hot! itll only cost ya a fuse! Or it could be that you are just too GIIIZZZAHEY for the task at hand! better stick to basket weaving!Dakota
Old Mar 4, 2002
VNlilMAN's Avatar
The Standard One
like i said, try switching the power and ground wire... cause i'm guessing the trunk light is similar to the dome light. it's a - and not a +. this one other guy was gettin the opposite effect to but thats cause it was a - wire. so try switching it and it should work.
Old Mar 5, 2002
haha got it pimpdakota! u put the basketwaving aside for a sec and it worked. it was too far back before that Y that goes to the brake light and trunk light, just popped it there and it worked. thanks for the help though guys!
danace99
23
Jun 28, 2015 08:49 AM
MamaBear2015
May 18, 2015 07:37 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
blackbullet
Dec 1, 2001 03:44 PM
NukeSilo
Nov 20, 2001 05:17 PM
