OBX B3 Bomb Exhaust?
Old Mar 3, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
OBX B3 Bomb Exhaust
Heye veryone, I have a question for you all about this B3 Bomb exhaust. I am thinking of buying this catback system and I am wondering what some of this piping connects to. Ok, I know where the muffler goes, and I know that at the end of the muffler piping goes the catalytic converter, then goes the long pip that connects to the headers. I was wondering though where that short pipe with the bend in the picture goes? I would really appreciate it if you all helped me clear up this problem. Thanks!
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Mvc-121D.jpg (35 Kb)
Old Mar 3, 2002
Essa's Avatar
Essa is an unknown quantity at this point
The short pipe should be install between the long pipe and the muffler.
If you joint the short pipe with the muffler, it will be call an axleback muffler.
Hope this is help
Old Mar 3, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
after the cat is that middle pipe, then the pipe on the left with the resonator closer to the back end of the car, and finally the muffler section
Old Mar 3, 2002
ZSKCivic01's Avatar
Extreme Member
what about the catalytic converter, which pipes does that go between?
Old Mar 3, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
where did you get that pic?
who are you buying it from?
and how much?
cause i've been lookin at that same exhaust for a while but haven't been able to get much info on it so i thought i was just going to have to get it and find out first hand
Old Mar 3, 2002
Essa's Avatar
By the picture you showed me, this is how it goes....
The long pipe already has a cat converter (the bubble pipe), connect the end that closer to the converter to the short pipe (maybe you should use a clamp or something to hold it tight). Connect the short pipe with the bolt on end to the muffler.
cukaracha
Aug 27, 2015 02:02 AM
ZSKCivic01
Texas
Aug 12, 2003 09:53 PM
ZSKCivic01
Aug 4, 2003 08:29 PM
ZSKCivic01
Apr 1, 2002 06:36 PM
ZSKCivic01
Mar 21, 2002 12:12 PM
