FS: Air Ride - Updated PICS!!!!!!
Old May 22, 2006
white_trash's Avatar
white_trash is an unknown quantity at this point
Almost Brand New Easy Street Air Ride Kit
Includes EVERYTHING you need.
Easy Plug-and-Play Installation.
Sale ALSO includes the Easy Street Auto Pilot Digital Air Management System
***Digital Air Management System is a 1200 USD upgrade which I am including in the Sale. Features of the Digital Air Management System are listed blow. It is a must have when you have air ride ***
Kit Includes:
- Easy Street Auto Pilot Digital Air Management System
- 2 Front 9-way dampening Air Struts
- 2 Rear 9-way dampening Air Struts
- 8 of our 3/8" chrome 300 PSI Valves
- Viair 380C Chrome Compressor
- 5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports
- 2 200 PSI Dual Needle Gauges with Chrome Bezels
- 40' of 1/2" D.O.T. Approved Air Line
- Nickel plated D.O.T. push to connect fittings
- 145-175 PSI Pressure Switch
- 50' of 1/4" D.O.T. Approved Air Line for your Gauges
- 90' of 16 Gauge Wire for Proper Valve Connections
- Detailed Installation Manual
-One touch ride height
Allows you to return to your ride programmed ride height without tapping switched and watching gauges. Whether your below, or above your height, just tough one button to return to your aligned height.
-Auto ride height on start.
Will lift your vehicle to the programmed ride height with the start of the engine. This feature can be turned
-Individual wheel control
Allows you to adjust each wheel separately. Also known as Front back side to side control.
-All inflate and deflate buttons
Also known as pancake control. Give you 4 wheel height control up and down with one switch.
-Digital Volt Meter
Reads the vehicles voltage to help prolong equipment and battery life.
-Auto leak Detection
Will monitor all 4 corners, if a leak occurs, the system will automatically add air accordingly and warn you of a problem.
-Tuning Feature
Teaches the system the exact requirements to lift each wheel. Ensures that the auto ride height function is perfect every time.
-Only one wire
No more running airlines, power lines, and wiring every switch independently. One wire does it all.
*** Please contact me for shipping costs. I will provide you a quote within 1 day of receiving your PM ***
Asking Price is: $ 2100 including the digital controls
PM me ur email address if ud like sum pictures aswell
Old May 25, 2006
PM's Replied!
PM's Replied!!!!!
PM's
REPLIED!
Last edited by white_trash; May 25, 2006 at 05:17 PM. Reason: Automerged Doublepost
Old May 26, 2006
Pm' Replied!
Old May 30, 2006
PM's Replied!
Old Jun 4, 2006
PM's replied!!!!!
Old Jun 4, 2006
HondaNation's Avatar
Got Bags?
HondaNation is on a distinguished road
whoa your price is hella steep maybe i should ask more for my kit
Old Jun 6, 2006
naww i think its reasonable, especially since the digital controls are included..... its a 12oo usd upgrade. what kit are u selling
Old Jun 6, 2006
Got Bags?
im selling my direct bolt on bag setup with digital controls as well my valves and digital controler are from airridetechnologies and my bags from AIM ind.
Old Jun 6, 2006
Got Bags?
Old Jul 29, 2006
PM's Replied!!!
Old Jul 29, 2006
pon55's Avatar
Did you hsave these on over the winter? If you did, any problems with freezing?
Old Jul 30, 2006
i had it on near the end of winter.... no problems with freezing.... the air tank has a valve on the bottom to flush out any moisture in the tank.
Wild Cranker
427
Jan 28, 2016 06:49 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Lopes101
Jun 7, 2015 08:04 PM
jc33312
May 12, 2015 03:17 PM
ImmortalEX
Nov 8, 2001 09:52 PM
