Can you install front sway bar for dx?
Old May 20, 2006
I3ananaFoo's Avatar
I3ananaFoo is an unknown quantity at this point
Exclamation Can you install front sway bar for dx?
My Civic doesnt have a front sway bar and i was wondering is there is a way to install a front sway bar. I've just got some wheels for the car hoping it would dramatically decrease the roll but it didnt do the trick.
I hate the roll in my car and I would rather invest in a sway bar than a strut bar.
Old Sep 8, 2006
brads05em2's Avatar
brads05em2 is an unknown quantity at this point
I have this same question
I have an '05 DX
Old Sep 8, 2006
sil04ver's Avatar
sil04ver is an unknown quantity at this point
Im 99% sure that you can, but Ive heard there can be some clearance issues if you have an exhaust on the car. Or was that in the rear?
Old Sep 8, 2006
skipbarber's Avatar
as far as i know, ALL dx's have mounts for the front sway bar, but not the rear. adding a front bar will reduce the slop. you can take any bar from any previous year dx and it will fit, but if you ever plan on doing an EX exhaust conversion it WILL NOT clear. youd have to get an EX front sway bar. endlinks are the same for all models.
Old Sep 8, 2006
mishqua's Avatar
mishqua is an unknown quantity at this point
maybe
I just installed one on my 03 dx, it didn't come with one. Turn your tires all the way to the left then on the passenger side look and see if you have the holes for the endlinks. If you have them you should be good, if u whant to be sure then just jack the car up there should be 2 sets of holes to mount the bushings, these are located maybe 6in behind the front tires in the middle of the chassie.
] Does that apply to 05-06? I have an 03 dx, I put a dx ST front sway on then upgraded my exhaust with an hp header complimented with a 2.25 exhaust fits sweet doesn't touch nor tap at all.
Old Sep 8, 2006
skipbarber's Avatar
it applies to all 7thgen model years. ST sway bars are meant to fit all trims, not just DX's it is still essentially an EX bar. but if you look up the dx and ex sway bars, they have different part numbers...take it from a guy that had to take out his front sway bar to let his EX down pipe clear..
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
andylao
Nov 4, 2001 01:19 PM
