[ 4-5 lug conversion : via RSX swap ]
Old Feb 28, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
Ok, looking at the two following brake assembly links side-by-side:
2001+ Civic
2002+ RSX
It appears to me that all you would need, besides some new rims, would be:
A.) RSX - HUB ASSY., FR. (#6) - [5 Lug/Hub Assembly]
B.) RSX - DISK, FR. (16") (#14) - [5 Lug/Rotor]
Assuming that our front caliper would fit over the new rotor, (which it looks like it would, if not then you would have to buy the RSX caliper assembly aswell). And whether or not your new rims would house the rotor and caliper.
If this were true, then the 4-5 Lug Conversion would be cheaper than most people expect (100$/front corner). Thanx in part to the fact that the RSX and CIVIC are so similar chassis/suspension wise.
Also, it leads me to suspect that the rear RSX brake assembly can be used with the civic also. Using this 4-5 Lug Conversion. Allowing us to have rear-rotors. Although that's a bit more pricey.
Just thought you'd like to know, I see alot of people posting about this topic.
]SiMKiN[
Old Feb 28, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
looks like it would work, the rear would be expensive though...you would need the master cylinder, proportioning valve, lines, ebrake-cables, LCA's maybe? Its a pricey swap.
Old Feb 28, 2002
2k1EXracer's Avatar
2k1EXracer is an unknown quantity at this point
The hub bearings are diff. part numbers so I dont think they are the same and probably wont fit. Why do you want 5 lug hubs anyway? Our cars will never make enough power to need them.
Scout1
Oct 5, 2015 01:33 PM
siliconvalley
Sep 15, 2015 09:48 PM
BJB
Sep 14, 2015 11:16 PM
Hatchness
Sep 14, 2015 09:02 AM
tomas6791
Sep 11, 2015 06:47 PM
