2000 watt Boss amp! $90 Shipped... PRICE DROPPED
For every sprinkle I find, I shall kill you.
$90 Shipping within the 48
This is in great working condition. Needs cleaned up a bit.
Boss RIPPER Series Car Amp
2000 watt max
4 CHANNEL MOSFET
Bridgeable
Power Amplifier with Remote Subwoofer Level Control
SPECIFICATIONS
Phase
switch / 0 - 180 degrees variable Cooling fans
Variable subsonic filter Line
and speaker level inputs
Tri-mode operation Bridgeable ModeÂ*
Variable
low pass crossovers Gain Control
Treble Boost 0-+18dBÂ* Â*Bass BoostÂ*
0-+18dBÂ*
Mobile-Emotions MOSFET power supply (except RIPD3)
Remote
subwoofer level control Line out (for system building)
Power &
Protection LEDsÂ* Â*VU meters (power level)
Ripper Class A/B Amplifier
Series
RMS power, 4 ohm
220w x 4
Max power, 2 ohm
500w x 2
Bridged power, 4 ohm
1000w x 2
Signal-noise-ratio
>105dB
Fuse Type / SizeÂ* 20A x 2
THD (4ohm)
0.01%
Bass Boost / Dampen FactorÂ* 0 ~ +18db / 180
Channel SeparartionÂ* 90 db
Low Pass CrossoverÂ* 45 Hz - 90 Hz
High
Pass CrossoverÂ* 80 Hz - 500 Hz
Frequency Response
5Hz - 50KHz
(+/-3db)
Size: 11.5" W x 2.5"H x 16 3/16"L
Cooling fans / Vu Power
Meters
95 shipped withen the 48<
Needler Monkey: wait that one messed up
Needler Monkey: Boss RIPPER Series Car Amp
2000 watt max
4 CHANNEL MOSFET
Bridgeable Power Amplifier with Remote Subwoofer Level Control
SPECIFICATIONS
Phase switch / 0 - 180 degrees variable Cooling fans
Variable subsonic filter Line and speaker level inputs
Variable low pass crossovers Gain Control
Treble Boost 0-+18dB  Bass Boost 0-+18dBÂ
Remote subwoofer level control Line out (for system building)
Power & Protection LEDs  VU meters (power level)
Ripper Class A/B Amplifier Series
RMS power, 4 ohm
220w x 4
Max power, 2 ohm
500w x 2
1000w x 2
Signal-noise-ratio
>105dB
Fuse Type / Size 20A x 2
THD (4ohm)
0.01%
Bass Boost / Dampen Factor 0 ~ +18db / 180
Channel Separartion 90 db
Low Pass Crossover 45 Hz - 90 Hz
High Pass Crossover 80 Hz - 500 Hz
Frequency Response
5Hz - 50KHz (+/-3db)
Cooling fans / Vu Power Meters
2000 watt max
4 CHANNEL MOSFET
Bridgeable
SPECIFICATIONS
Phase
Variable
0-+18dBÂ*
Remote
Power &
Series
RMS power, 4 ohm
220w x 4
Max power, 2 ohm
500w x 2
1000w x 2
Signal-noise-ratio
>105dB
THD (4ohm)
0.01%
High
Frequency Response
5Hz - 50KHz
(+/-3db)
Meters
2000 watt max
4 CHANNEL MOSFET
SPECIFICATIONS
RMS power, 4 ohm
220w x 4
Max power, 2 ohm
500w x 2
1000w x 2
Signal-noise-ratio
>105dB
THD (4ohm)
0.01%
Frequency Response
More pics added. If you need to see more, let me know what you want to see and I'll take them. And to answer your question... RMS power, 4 ohm
220w x 4
220w x 4
cukaracha
May 18, 2015 11:21 AM
What_It_Do
May 10, 2015 05:31 PM
cukaracha
Apr 26, 2015 08:39 PM
