Push button ignition & steering wheel lock
Bodacious Member
I have a push button ignition setup in my car, but no accessory switches, so I still have to turn the key to "on" for it to work. I've been researching about mounting switches for all the acessories (or wire them all to one switch, whatever) so that the key doesn't have to be in to start it. However, the steering wheel lock is mechanical, is it not? Is there any way to have a switch on the steering wheel lock or is it purely mechanical?
BTW, I'm planning on a hidden switch under the seat that will disable starting the car at all (anti-theft device), and then one switch for the accessories/steering-lock and the push-button starter.
Thanks.
Thanks.
the steering wheel lock is mechanical, you could try and take the column apart and rig something up...not sure how it is on a honda, but in a ford its just a pin that you can take out and the lock is gone.
Bodacious Member
hmm. i dont know if i want to just take the lock off...it's a pretty good anti-theft device in and of itself. Anyone know more about disabling it though? I'd like to not have to use my key at all, but I may end up disabling the lock.
im ontot he same plan as u aside form everyone getting in my car.
im trying tof igure out if i can use a channel on my alarm to turn the accessories on and get the car ready witht he push of the button. instead of switches. and then jsut use a start button in car.. hmmmm
im pondering.. pondering lots i tells ya
honda200192
May 31, 2015 05:57 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
