What are the torque specs for installing spark plugs?
13-15 ft/lbs with beam style wrench. not tight at all and actually they get very loose all the time. so its good to retorque them whenever you can maybe once a month.
Originally Posted by boosting
Thanks, most helpful.
How about using dielectric grease in the COP boots?
Thanks,
biz
Install dry...it is!
I know that the OEM Honda brand spark plugs come properly gapped, but it is always a good idea to check. So...what is the proper gap?
Thanks!
biz
Check twice...Do Once!
Thanks!
biz
Its more or less irrelevant what the gap is, .044 is correct, but unless you're using copper plugs, leave the gap alone, platinum and iridium electrodes will crack off if you regap it too much, and they're usually set where they need to be.
159
Jul 5, 2015 09:54 PM
danace99
23
Jun 28, 2015 08:49 AM
