Help!! Tranny Gone Bad!!!
Old Apr 30, 2006
hondaqueen's Avatar
hondaqueen should not be trustedhondaqueen should not be trustedhondaqueen should not be trusted
Can anybody tell me if I can put and 2004 Civic Dx Transmission in a 2001 Civic Dx. Please Help!! My transmission went out and I brought a 2004 Transmission but not sure it'll work. It a automatic.. Thanks!!!!!!!! [/B][/B]
Old Apr 30, 2006
diskreet's Avatar
the 01-05 are the same under the hood. so an 01 dx has the same tranny as an 04, 05 dx. The engine is exactly the same so I can't see any problems.
Can anyone confirm 100%?
Old Apr 30, 2006
hondaqueen's Avatar
Yea, that's wat I thought. But all this mf keep telling me that its not gona work.Because of the gear ratio's and all that crap. See the bad thing about that is that I brought an 04 tranny with only 11,000 miles on it and i want this one i got....I dont wana waste my money.
Old Apr 30, 2006
diskreet's Avatar
i think they are the same gearing. I doubt that should matter much anyway since the tranny controls the shifts according to throttle, rpm, and accelleration/decelleration. I don't think the ECU decides on when to shift
Old Apr 30, 2006
hondaqueen's Avatar
Are you guessing or have you done any research on it.
Old Apr 30, 2006
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
of corse it is going to work..
Old Apr 30, 2006
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
why did you buy an auto tranny?
besides that, if you are replacing the WHOLE tranny, it will be as simple as taking the old one out and bolting the new one in.
Old Apr 30, 2006
Al Gore FTW's Avatar
jdmtytedoridori
yeah it will work.
Old Apr 30, 2006
hondaqueen's Avatar
Cause my car is orginally is an atomatic and my transmission went out. I asked and they told me that it would be more enspensive to switch to manual
Old Apr 30, 2006
diskreet's Avatar
that is pretty true. the parts OTHER than the tranny needed (cables, clutch pedal and lines, shifter, etc) add up to be a lot and its a good amount of work.
Old Apr 30, 2006
hondaqueen's Avatar
Yea, I know but I hope that this 04 tranny fit on me 01 civic cause im about to pull my hair out with this high prices that everbody giving me to replace or rebuild my tranny
Old May 1, 2006
jdmtytedoridori
its the same thing, man. it will go right in.
Old May 1, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Bolt and play come on now.. How did you screw it up in the first place? Or did you just get one of those crap trannys from honda to begin with?
Old May 1, 2006
red_sun's Avatar
Boost is so good make you wanna slap ya mamma
red_sun is on a distinguished road
The 01-05 auto trannys are all essential the same they all have the same housing and they all bolt up the same the tranny with different gear ratios is the ex it has slightly shorter gear ratios. It’s good that you got an 04 tranny they are supposed to not have problems and supposable they shift smoother
When I blew my auto tranny a couple of weeks ago the best price I found for a used auto tranny with low miles less than 20,000 was $650 so I did an auto to manual swap instead for just over $1000 I did all the install work myself so labor was free. So I kind of know what your going through.
Old May 1, 2006
turboengnr's Avatar
DONT PANIC
The gear ratios will not matter. Your speedo gear will compensate for the different speeds in each gear, so your speedometer will still read correctly. And the ECU does decide when to shift the tranny, but it does so by RPM and Load, not speed. So you should have nothing to worry about.
Old May 1, 2006
hondaqueen's Avatar
Ok, thanks everybody for you feedback. I was worried cause I got really, really good deal. We pulled it out of the car with 11, 000 miles on it. And I paid $350. I was really blessed for that price. Anymore comments would be appreicative
Old May 14, 2006
luznilla's Avatar
luznilla is an unknown quantity at this point
Damn, I need one for an 01 ex mt, shop quoted me $2300 for new tranny and clutch/flywheel while theyre in there...
way too much, going to do it myself but need decent parts i hope to get for under $1000
Old May 18, 2006
hondaqueen's Avatar
Hello, I wanted to say thanks to all of you guys imput. I finally recieved my car back. And the only problem with that transmission is that when i go thru park to drive the Nuetral like deos not light up green unless its sitting in neutral. Im so happy i convert for 01 tranny to 04
Old May 20, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I have everything you need minus a few minor parts to switch to a manual. I have done it so I can provide you with direction on how to do it. It is really not hard at all. What I have would give you the following:
-5spd manual tranny from an ex 30K miles (better gearing that that from a dx, and yes it would work in your dx I garauntee it)
-ACT prolight flywheel 15K miles
-Exeedy clutch 15K miles
-Subframe for a manual tranny car
-engine mounts with urethane inserts
-shifter cables
-Wiring mechanism to make it work with an auto ECU
I can sell all of this for $750 + shipping
you would just need a couple of misc pieces like the master cylinder and fluid bottle, clutch lines (can make your own for $10), axles (exchange your old ones at an autoparts store for new for around $150), manual tranny brake, and clutch pedle.
cukaracha
30
Jul 26, 2015 12:01 PM
jzhartman
22
Jul 23, 2015 10:42 PM
671civicLX
Jul 9, 2015 03:22 PM
Bounddyy
Jul 8, 2015 11:22 AM
cgavin1
Jul 7, 2015 07:10 AM
