Blitz valve not opening below 6 psi
Old Apr 26, 2006
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
I have my blitz dd valve set to fully loosen and it still will not let air out under 6 psi. I really cant have this surge and want to take care of it. My vaccum soruce is the line from the intake mani to the check valve. I run my emanage pressure sensor and boost gauge off it as well just fine. The valve is up right before the frontmount in the wheel well. The vaccum line is as short as i can get it but its still a decent distance....Any suggestions?
Old Apr 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Have you checked whether or not you have the high pressure spring or the low pressure spring? If you're running the 15+ PSI spring, that might do it.
Not terribly familiar with it but is it one of the valves with 2 vac ports so you can add a boost assist to the second port?
Or could it be jammed?
Old Apr 26, 2006
iamboo's Avatar
Retired - SoCal FI Mod
cut the spring a couple coils...
Jul 12, 2015 11:54 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
General 7th Gen
Jul 9, 2015 10:17 PM
1khilari
Jul 9, 2015 08:12 PM
AaronSorenson
Jul 7, 2015 09:40 PM
