supercharger or Turbo
Old Apr 21, 2006
NoMoreHonda's Avatar
Go Dodgers
NoMoreHonda is an unknown quantity at this point
I'm wondering what is better, supercharged k20a3 or turbocharged a3. Plz help me out. Not really into a lot of HP, but i want some power in the motor.
Old Apr 21, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
if your not so into power but want enough, just get an a2
edit: sorry just realized maybe u alreay have an a3...anyhow i prefer turbos but hey i guess its up to you. either way low boost with a good tune should give you nice power and not so many problems.
Old Apr 21, 2006
RHCP0801's Avatar
he already has a swap, why would he do another one
Old Apr 21, 2006
ya thanx i realized that after.
Old Apr 21, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
A3? This isnt for you i take it
Old Apr 21, 2006
RHCP0801's Avatar
man im confused....
Old Apr 22, 2006
Go Dodgers
to clear the cofusion.. i have the k20a type r motor.. i want the lower compression engine for turbo set up.
Old Apr 22, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
so let me get this right. you have a type r motor now. but looking for more hp and thinking about a a3 swap w/ turbo/sc???
Old Apr 22, 2006
Go Dodgers
just an a3 with turbo.. i'm not looking for more HP.. i want the power, but dont want the high compression ratio
Old Apr 22, 2006
R1Style's Avatar
Put a Turbo on your K20A and run lower boost. Get a good shop to tune it and it will run safetly.
You'll make more power if not the same if you were to drop in a K20A3 with a turbo and run more psi. Plus the money you'll save swapping another motor in and out.
Old Apr 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I'm thinking KEEP the A block, its got goodies like piston oil squirters that the A3 doesn't have, just drop a set of 9:1 pistons in it.
Old Apr 22, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
S/c that beast. Why would you take that engine out? I am a little baffled cause that sounds crazy. A s/c k20a is an excellent combo, they use them in the atom, the go cart on top gear that races a bike.
Old Apr 23, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
i say s/c it for that down low power
Old Apr 24, 2006
turboengnr's Avatar
DONT PANIC
turbocharge it.
superchargers have an inherent parasitic loss from the fact that they are driven from the crank.
also, turbos only require a boost controller to up the boost (30 seconds).
superchargers require swapping pulleys and belts (2 hours).
Old Apr 24, 2006
2 hours? lol oh come on now, i can do mine in 10 mins.
Old Apr 24, 2006
turboengnr's Avatar
DONT PANIC
well, if you have to ask "should i turbo or supercharge it?", it will probably take you 5 days.
j/k
Old Apr 24, 2006
this is true lol, but i know him hes a good guy. and honestly on an A3, with one of your setups ;-) maybe you could do it and get rev-hard to make one. Just a thought
Old Apr 24, 2006
turboengnr's Avatar
DONT PANIC
revhard already wants to copy my 03 Si intercooler piping. lol. And we just swapped out the manifold and turbo we had on it for the revhard manifold and a t3/t04e with the revhard downpipe. Robs Si is gonna kick *** when were all done.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
tomas6791
Sep 11, 2015 06:47 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
