ABS light how to fix ?
Um...take it to a dealer or repair shop and have them look at it. That light comes on when there is a problem with your ABS system, which is really something that should be looked at, considering it affects how your car stops moving...
Mine came on once after being caught in a flash flood so I took it in to be safe just incase. Nothing was wrong, they just had to reset it, cost like 50 bucks for them to inspect it but worth every penny. Things like that should ALWAYS be checked out by the dealer. Good luck, hopefully nothings wrong and just needs to be reset.
~n~
~n~
Official Rattlesnake Hunter
ya it's a good idea to try.
He wants you to reset your ECU!
unplug the bat. for about an hour (IMO) plug it back in start car, check for CEL (check engine light)
Originally Posted by jay78
i alrady hve cel on cuz of my cat
so that plug out from ecu for an hour and then plug it back ?
So you can watch ALL CELS that come through.
Any who your cel due to your cat & your ABS are two seperate lights.
Un-plug you battery. Wait an hour. plug back in. Start car.
If the ABS is on still go to the dealer!
here i hve remote start and i didnt install the switch to turn the alaram off (the one people install under the hood and under the stering)
i do hve remote
when i disconnect the battery after hour connect the battery my alaram will be armed now i can just use my remote i dont need to use that switch $hit do i.....would it be any problem ????
i do hve remote
disconnecting the battery will not reset the ecu...that is obd I, we are obd II.....you need a scanner to read the code and find out what the problem is, fix the problem then clear the code.
I Hunt Goats, Rams, And Mustangs.
Originally Posted by 02BLKCIVIC
Soooooooooo, OBD1 will RESET?????????? Or NOT??????????? ^^^^^
yaa
it came on cuz when i was racing my one wheel was speining faster then other and that made my light go on
so now i need find 2pin connector for this if some else knows which one
i need to jump it.........
not the SRS 2pin connector i belive (yellow one)....
will be another 2pin connector somewhere under the staring ??? supose to white or green
Originally Posted by SilverVTEC
oh and i believe that disconnecting the battery or taking out the ECU fuse does reset the ecu. i know because i have had to do it a couple of times.
now where is the ecu fuse........would it be safe to do this
also if some one can find out two pin connector by the passanger side under the dash...
can't find under the staring so has to be somewhere by ecu....thankx
