ABS light how to fix ?
Old Apr 18, 2006
jay78's Avatar
jay78 is on a distinguished road
does any1 had this prob
my ABS light popup in my dash
i hve about 55,800 miles
if some1 knows how to fix this plz help me
thankx
Old Apr 19, 2006
Mystic3030's Avatar
Yup, i'm an A$$hole.
Um...take it to a dealer or repair shop and have them look at it. That light comes on when there is a problem with your ABS system, which is really something that should be looked at, considering it affects how your car stops moving...
Old Apr 20, 2006
jay78's Avatar
thankx i will take it their then
Old Apr 20, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Agreed BIG problem!!!
Dealer OR your trusted mechanic!
Old Apr 20, 2006
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Mine came on once after being caught in a flash flood so I took it in to be safe just incase. Nothing was wrong, they just had to reset it, cost like 50 bucks for them to inspect it but worth every penny. Things like that should ALWAYS be checked out by the dealer. Good luck, hopefully nothings wrong and just needs to be reset.
~n~
Old Apr 20, 2006
jay78's Avatar
thankx dude
Old Apr 20, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
try unplugging and plugging your bat then drive it around see if it come on. if so take it in.
Old Apr 20, 2006
jay78's Avatar
bat ?
Old Apr 20, 2006
02BLKCIVIC's Avatar
ya it's a good idea to try.
He wants you to reset your ECU!
unplug the bat. for about an hour (IMO) plug it back in start car, check for CEL (check engine light)
Old Apr 20, 2006
jay78's Avatar
i alrady hve cel on cuz of my cat
so that plug out from ecu for an hour and then plug it back ?
Old Apr 20, 2006
02BLKCIVIC's Avatar
Do you have a code reader??? if not I would sudgest in investin in one! (e-bay $30)
So you can watch ALL CELS that come through.
Any who your cel due to your cat & your ABS are two seperate lights.
Un-plug you battery. Wait an hour. plug back in. Start car.
If the ABS is on still go to the dealer!
Old Apr 20, 2006
7thGenerasianCivic's Avatar
My ABS went on before after doing some FWD burnouts. I took the fuse out and disconnected the battery. After awhile it went away. I'm still not sure how I fixed it. hahahaa
Old Apr 20, 2006
MarkieMark's Avatar
MarkieMark will become famous soon enough
my abs light turns on when i first start the car then it disappears in like 2 secs.
is that normal? or should it be off all the time.
Old Apr 20, 2006
02BLKCIVIC's Avatar
Yes it's normal.
All the light should come on for 2 sec...
Old Apr 20, 2006
jay78's Avatar
here i hve remote start and i didnt install the switch to turn the alaram off (the one people install under the hood and under the stering)
i do hve remote
when i disconnect the battery after hour connect the battery my alaram will be armed now i can just use my remote i dont need to use that switch $hit do i.....would it be any problem ????
Old Apr 20, 2006
02BLKCIVIC's Avatar
un arm
diconect
wait
reconnect
start
check for lights
Old Apr 20, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
disconnecting the battery will not reset the ecu...that is obd I, we are obd II.....you need a scanner to read the code and find out what the problem is, fix the problem then clear the code.
Old Apr 20, 2006
02BLKCIVIC's Avatar
Hmmm! only obd1 will reset hu...
Old Apr 21, 2006
good one
Old Apr 21, 2006
02BLKCIVIC's Avatar
Soooooooooo, OBD1 will RESET?????????? Or NOT??????????? ^^^^^
Old Apr 21, 2006
if the car is OBD I which ours in NOT...then yes disconnecting the battery for a certain periode of time will reset the ecu....so if you want to clear codes on ours you need a scanner.
Old Apr 22, 2006
02BLKCIVIC's Avatar
I have a scanner!
I understand my car is obd2!
Just clearifing...
Old Apr 25, 2006
jay78's Avatar
i found out how to take care this
scanner wont clear the code....i tryd....
i will wirte diy on this tomo if i get time....
Old Apr 26, 2006
02BLKCIVIC's Avatar
no problem with your ABS then...?
Old Apr 26, 2006
jay78's Avatar
yaa
it came on cuz when i was racing my one wheel was speining faster then other and that made my light go on
so now i need find 2pin connector for this if some else knows which one
i need to jump it.........
not the SRS 2pin connector i belive (yellow one)....
will be another 2pin connector somewhere under the staring ??? supose to white or green
Old Apr 26, 2006
02BLKCIVIC's Avatar
Wo! Good Luck!
Old Apr 26, 2006
SilverVTEC's Avatar
SilverVTEC is an unknown quantity at this point
oh and i believe that disconnecting the battery or taking out the ECU fuse does reset the ecu. i know because i have had to do it a couple of times.
Old Apr 26, 2006
jay78's Avatar
disconnecting battery didnt work for me
now where is the ecu fuse........would it be safe to do this
also if some one can find out two pin connector by the passanger side under the dash...
can't find under the staring so has to be somewhere by ecu....thankx
Old Apr 26, 2006
02BLKCIVIC's Avatar
Owners Manual! has a FULL diagram guys!
Old Apr 26, 2006
civicstylez's Avatar
civicstylez is an unknown quantity at this point
my abs light has been on also..... but my friend told me it was a fuse prob. duno i havent taken it in yet....... if any one finds out lemme kno also
