Altezza tail light CONDINSATION!!
Old Feb 26, 2002
andoy's Avatar
andoy is an unknown quantity at this point
sup guys...
i just got a new Altezza carbon fibre tail light, and after a week of driving i noticed condinsation forming inside the housing. Is this a defect on the lights or is it normal?? how can i prevent it from forming again??
thanks...
andrew
Old Feb 26, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
youll have to get the water vapor out of the light then seal it with clear kitchen and bath silicone
Old Feb 26, 2002
cwick187's Avatar
cwick187 is an unknown quantity at this point
First off, you should have just kept your factory tail lights in (just MO) But you'll need to take the light out and put a beed of silicon around the light where the two peices(the outside and inside part of the light) are connected with eachother. My friend had the same problem and that seemed to fix it.
Old Feb 26, 2002
andoy's Avatar
i guess i would have to take it off agian.. ohh well.. worth a try sealing it with silicone.. thanks guys!!!
ease up
andrew
Old Feb 26, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
that happened to me too man..i have still yet to fix the problem..
i'm beginning to think these lights are pretty much junk...
if you seal it up with silicone that's not gonna help because the water vapour is just getting sealed in there...i htink anyways...correct me if i'm wrong..
Old Feb 26, 2002
civic2k2lx's Avatar
civic2k2lx is an unknown quantity at this point
i think if u use a blowdryer to get the water out that would work
if not, bring the lights back for a new fresh pair, and before putting them on, seal them[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 26, 2002
theSHADIEST's Avatar
theSHADIEST is an unknown quantity at this point
civic2k2lx is right. if you use a hair dryer on the outside of the lights it will evaporate the condensation on the inside. I am not sure if you are familiar with rain-x anti fog. This works very well for me on the inside of my car. I replaced my factory tails also, and before I had any condensation build up I took that rainx solution and diluted it wil like 3 parts water one part solution (roughly 3 shots of H2O and one shot or rainx)
and used a spray bottle and sprayed that inside the teeza...I then used a hair dryer and dried all of the water up...hence no condensation inside. Oh dont keep the dryer on very long b/c you will heat up the factory sealant on the teezas and that may cause condensation quicker....good luck
Old Feb 26, 2002
7GRev's Avatar
7GRev is an unknown quantity at this point
I havent gotten any condensation yet, the best idea is to seal around the light and trun with Silicon, it works really well.
Old Feb 27, 2002
zackde's Avatar
zackde is an unknown quantity at this point
ANDOY.....
how much is ur CF TEZZA??....
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 12, 2015 11:38 AM
mrad55
Nov 22, 2001 06:29 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
