Super-Safe Nitrous Set-up
Old Apr 11, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
Okay I'm thinking of running nitrous on my AUTOMATIC 2005 Civic, its an LX i believe.
I want a really safe set-up so that theres little to no chance of blowing it up so im thinking that if I do these mods then i will be fine, feel free to critique me because I need people with experience and such
< 75 shot wet nos kit ( leaning towards zex)
bigger fuel injectors ( rsx ? maybe bigger?)
new pistons ( dezod's? )
intake
exhaust
header
controller ( ive seen this where it wont let you spray in first OR under a certain rpm OR if your not in WOT )
My car is totally stock at the moment other than sound system.
Old Apr 11, 2006
djmota's Avatar
intake
exhaust
header
I really hate to burst your bubble here but you lost the whole safe thing with the first word of your post "Automatic" You should be more worried about your trans than your engine. On an auto the very most I would recommend would be a 50 shot. Even that amount will probably shorten the life of your trans. Engine wise you wont need injectors or pistons with anything up to a 75shot. Also add colder spark plugs to that list. check out the n20 faq
Old Apr 11, 2006
the whole < part meant less than 75 shot, okay so i just need injectors/spark plugs and what would you suggest I do to the tranny? tranny cooler?
Old Apr 11, 2006
ajhdragon's Avatar
7thgens official a$$hole
you don't need injectors.
Old Apr 11, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
if u pick the zex wet kit is adds all the fuel u need......when i had nitrous in my old car i ran it in a way with a wideband o2 sensor so that if the car went lean it shut off the nitrous(i had and bottle opener)and it wouldn't turn the bottle on until it was fixed.
Old Apr 11, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Maybe think about investing a new fuel pump as well to make sure you always are able to supply enough fuel.
Automatic's aren't the best choice for power in our cars. Talk to some of the automatic turbo guys though. Tnaaf is the first one that comes to mind and ask him what all he's done.
Old Apr 11, 2006
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
def. msd window switch! -fo' sho' haha
Old Apr 12, 2006
eye_see_you's Avatar
let the devil out
how about what I did with 16 psi of boost on an auto I built my tranny with the tci kit and switched to redline fluid otherwise you better just do a manual swap if you really want alot more from it
Matteo
Oct 25, 2015 05:46 AM
ttamrekab
Sep 28, 2015 01:22 AM
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
supermex
Feb 1, 2002 09:05 AM
