Explanation of the Anti-Lag Tune for n00bs
Old Apr 9, 2006
dezod's Avatar
7thgen Power Maker
Originally Posted by Innovative Turbo
ALS, or Anti-Lag System, also known as bang-bang, is an engine management technique that minimizes turbo-lag.
Turbo systems can exhibit what is known as turbo-lag, which is the time needed for the turbocharger to gain enough speed for the compressor wheel to pressurize the intercooler, tubing and intake-system of an engine.
The amount of turbo-lag or time, depends on many factors such as rotating-group inertia, how well the componenets in the system work together, back-pressure before and after the turbo, engine (volumetric) efficiency, camshaft spec, etc. . In race cars it is common to fit relatively large turbochargers in order to produce enough airflow to provide desired engine output. Big turbochargers can display significant amounts of lag (on small displacement engines) due to their increased rotational inertia. The lag-issue, is partly dealt with by fitting a turbo with a Dual, Ceramic Ball Bearing System in the center section, such as the system produced by Innovative Turbo Systems. Another helpful addition is the bypass valve or dump valve, which operates during part-throttle or when the driver lifts. These valves will help reduce the load on the turbo and allows it to free-wheel, keeping the rotational speed higher – thus reducing turbo-lag. In race cars where immediate torque and engine response are critical factors, most applications can benefit from the use of anti-lag systems.
How ALS works:
The ignition timing is retarded with 25-30° or more and the air/fuel mixture is made richer at low throttle opening and low load. With the ignition timing delayed, the air/fuel mixture reaches the exhaust tubes mostly unburned and because the exhaust system’s temperature is higher than the flash point of the air/fuel mix, the unburned fuel explodes in the exhaust tubes. The turbo is accelerated by the increased temperature/pressure and the rotational speed of the turbo is kept high. While ALS is engaged, full boost is available the moment the throttle is opened.
Some downsides:
An immediate increase in exhaust gas temperature (800°C to 1100°C+) whenever the system is activated puts greater demand on all turbo-system components - reliability becomes a major concern; the turbocharger and exhaust-manifold tubing must be made with the best available materials, driving the cost higher. ALS is prohibited from use in certain racing series.
Old Apr 9, 2006
diskreet's Avatar
Good to know for people who want to use it, but generally this is not the best system to use on the road, correct?
Didn't they do this in rally a little while back, till it was prohibited by new regulations, too?
Old Apr 9, 2006
dezod's Avatar
7thgen Power Maker
A much more mild version can be implemented on a street car.......
Old Apr 9, 2006
blouisgod's Avatar
Life Begins > 6800rpms
is there a way to control it for just when you want ALS and then be able to turn it off? btw good info once again paul.
Old Apr 9, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Those EGT's are ridiculously high.
Old Apr 9, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
is this similar to WRC miss-firing system?
Old Apr 10, 2006
dezod's Avatar
7thgen Power Maker
Your EGTS can get pretty high and cause a lot of strain on the system....
Old Apr 10, 2006
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
yeah, think what kind of cylinder pressures there are with a turbo motor, ok now apply a good portion of that pressure to the exhaust mani/ and piping, doesnt sound smart for a street car unless you absolutely need it.
Dezod could you elaborate on the milder version? what are the differences?
Old Apr 10, 2006
dezod's Avatar
7thgen Power Maker
Just being not as aggressive on timing and such.
Old Apr 11, 2006
turboengnr's Avatar
DONT PANIC
You can pull around 5-7* of timing in 0 vaccum and the first few psi, along with a/f ratios in the mid 10's. This can increase the spoolup time by 500 rpm or so and still be relatively reliable on the street.
Old Apr 11, 2006
andyman97's Avatar
Turbo Guru
Worst thing I've heard of happening is a cracked head from too much heat. Only system you'll find this on for the 7th gen is the AEM. You can switch it on and off with a laptop.
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
