what settings do i use on my e-manage? (rotary)
Old Apr 5, 2006
ncirom2003's Avatar
yes ive searched, all ive seen is like ten different answers and reasons, now this is what i have to work with.
02 lx, but with a ex head swap. so ive only got that one wire from the solenoid into the car, i hooked it up to vtec output. ok what settings?
Old Apr 6, 2006
Logan3024's Avatar
You have to use 4-8-c. This works for my car (same setup as you), but some will say that this doenst engage vtec, As long as you change the vtec output jumper (JP3) to 2-3, it will engage. But DO NOT touch JP4, because the emanage will then look for a vtec signal from the ECU, which you dont have and it will throw an error.
Seems like the guys with the EX ecu are running 4-8-e, my car wouldnt even start with that setting, Let me know how it goes.
break down of the jumpers **at bottom**
http://www.mohdparts.com/emanage/EmanageFAQ.txt
Jumper 4 needs to be 2-3
Old Apr 6, 2006
ncirom2003's Avatar
yea i called an emanage tech support line directly and they said 4-8-c or 4-8-d
ill go with what you have, thanks!
Old Jun 23, 2006
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
Hey i got a problem i used this setting and its reading 4000rpm on idle 4-8-c
Old Jun 23, 2006
dezod's Avatar
7thgen Power Maker
4-8-C or 4-8-E
Make sure your throttle is calibrated properly, jumpers are set properly and it's wired correctly.
Old Jun 23, 2006
yea i put it on, i was talking to brad about it and he was talking to u lol on aim. hahahahah ROFL he was reading what u wrote to me and what i said to u lol.
Yo dezod i fixed the idal problem now and yet another problem came up. Emanage is throwing a code 11 at me, which is airflow input. I cheked the wiring and its fine. Any thoughts?
Old Jun 23, 2006
dezod's Avatar
7thgen Power Maker
Sure bout wiring being correct? That is usally associated with wiring.
Old Jun 23, 2006
ok the input wire green/red to white and output green to green/red
Old Jun 25, 2006
ncirom2003's Avatar
i thought input was yellow.
Old Jun 25, 2006
???? Dont scare me, show me where you saw that. Let me know asap man i dun want to blow something up.
Old Jun 25, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you wont blow anything up. If its not engaging, and all your setting are right then try connecting to the other vtec wire.
Old Jun 25, 2006
ncirom2003's Avatar
when i was wiring it up i used the emanage instructions, use those and go over the colors.
some of the colors are wrong on the 7thgen write-up diy
Old Jun 26, 2006
dezod's Avatar
7thgen Power Maker
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
