what settings do i use on my e-manage? (rotary)
Subscribe
Apr 5, 2006
yes ive searched, all ive seen is like ten different answers and reasons, now this is what i have to work with.
02 lx, but with a ex head swap. so ive only got that one wire from the solenoid into the car, i hooked it up to vtec output. ok what settings?
Apr 6, 2006
You have to use 4-8-c. This works for my car (same setup as you), but some will say that this doenst engage vtec, As long as you change the vtec output jumper (JP3) to 2-3, it will engage. But DO NOT touch JP4, because the emanage will then look for a vtec signal from the ECU, which you dont have and it will throw an error.
Seems like the guys with the EX ecu are running 4-8-e, my car wouldnt even start with that setting, Let me know how it goes.
break down of the jumpers **at bottom**
http://www.mohdparts.com/emanage/EmanageFAQ.txt
Jumper 4 needs to be 2-3
Apr 6, 2006
yea i called an emanage tech support line directly and they said 4-8-c or 4-8-d
ill go with what you have, thanks!
Jun 23, 2006
Hey i got a problem i used this setting and its reading 4000rpm on idle 4-8-c
Jun 23, 2006
4-8-C or 4-8-E
Make sure your throttle is calibrated properly, jumpers are set properly and it's wired correctly.
Jun 23, 2006
yea i put it on, i was talking to brad about it and he was talking to u lol on aim. hahahahah ROFL he was reading what u wrote to me and what i said to u lol.
Yo dezod i fixed the idal problem now and yet another problem came up. Emanage is throwing a code 11 at me, which is airflow input. I cheked the wiring and its fine. Any thoughts?
Jun 23, 2006
Quote: yea i put it on, i was talking to brad about it and he was talking to u lol on aim. hahahahah ROFL he was reading what u wrote to me and what i said to u lol.
Sure bout wiring being correct? That is usally associated with wiring.
Jun 23, 2006
ok the input wire green/red to white and output green to green/red
Jun 25, 2006
i thought input was yellow.
Jun 25, 2006
???? Dont scare me, show me where you saw that. Let me know asap man i dun want to blow something up.
Jun 25, 2006
you wont blow anything up. If its not engaging, and all your setting are right then try connecting to the other vtec wire.
Jun 25, 2006
when i was wiring it up i used the emanage instructions, use those and go over the colors.
some of the colors are wrong on the 7thgen write-up diy
Jun 26, 2006
Subscribe
