Gauge needle alignment
i just did the Diskreet DIY LEDs and i finished it all.....buuuuut
the speedometer (speed not RPM) dosent work correctly and what am i suppost to be idle at? gas is 95 % correct temp is 100% im sure , any tips on fixing the speed?
the speedometer (speed not RPM) dosent work correctly and what am i suppost to be idle at? gas is 95 % correct temp is 100% im sure , any tips on fixing the speed? Joined: Feb 2006
Ruh Roh. From what I've heard if you take the needles off and don't put them back on right and use the cluster, You be screwed...
Idle on my car is around 800 RPM's, if that helps...
yeah the speed is the only thing i need i lift it andit quickly falls down fast, isnt it suppost to slowly come down to the bottom not so fast like it wieght 232323 pounds
did you take em off and put it back in the same position? and i thought all the newer clusters had auto calibrate when you plug it in? i'm really not sure how to adjust them. Are you sure its not just stuck? Also you could've ruined it if you played with the needles while the cluster was plugged in already.
the speed moved when i was putting it back on and i was so pissed because i was doing so well thats all i really gotta play with and adjust thought someone would have some other tip other than play and adjust it well no one said it but im sure thats all i gotta do till i bring it to a shop
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
260000milesgoal
Sep 25, 2015 07:41 PM
