Megan upper strut bar rattling
Old Mar 31, 2006
Victorious's Avatar
Victorious will become famous soon enoughVictorious will become famous soon enough
Just installed a Megan upper front strut bar, and my car is rattling everytime I'm not moving.
I had a generic one on before, and there were no problems.
I am thinking that the Megan one is lower, and is vibrating against an engine part.
I'm thinking I should add some washers under the strut bar mounts on the bolts to increase the height of the strut bar.
Not too sure though... any opinions?
Old Mar 31, 2006
LiKEaFeRiO's Avatar
Since it happens when you aren't moving why don't you open the hood and find the rattle?
I'm guessing its the intake if you have one.
Old Apr 1, 2006
Victorious's Avatar
thanks,
no intake though
i think it's rattling against the part thats above the engine.
what is that... the brake reservoir?
i'm probably going to put in some washers and see what happens
Old Apr 2, 2006
db17k's Avatar
db17k is an unknown quantity at this point
Originally Posted by Victorious
thanks,
no intake though
i'd think that adding washers would compromise some of the the rigidness and stability that the strut tower bar provides, because the mounts won't be as securely bolted down to the strut tower.
if it is the brake reservior/master cylinder that is rattling against it, i believe another member mentioned that there is a second mounting point for the reservior located just below the original location that gives enough clearance for the bar.
Old Apr 2, 2006
diskreet's Avatar
You can also wrap the reservior is a wrist band and tape the bottom to keep it on if that is what is happening. (That is unless you buy those overpriced reservior wrap things which are basically wrist bands for $40 more)
Old Apr 2, 2006
mikem317's Avatar
mikem317 should not be trusted
Time to go back to the generic cheapy, eh?
Old Apr 3, 2006
Victorious's Avatar
yeah the generic one had a higher arch to the bar
possibly providing less stability?
Old Apr 5, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
so have you looked upder the hood while its idling to see what is rattling.. other than that you wont be able to tell what it is hitting till a month or 2 down the road where you can see wear & tear from the 2 parts rubbing
Old Apr 27, 2006
GhostAssassian's Avatar
GhostAssassian is an unknown quantity at this point
sorry if this is old
i was having the same prob
the clutch cable resivour can be mounted lower on the bracket below and the knockin nose is from that silver tubing for the AC i just ziptied that off and the noise went away. Hope that helps
Old Apr 27, 2006
Victorious's Avatar
yeah I haven't had time to do anything yet because of exams
I just took off the bar for now and I'm going to fix the problem next week probably
thanks though!!
Old Apr 30, 2006
Victorious's Avatar
yeah i put in some washers and the rattling went away
quick fix but handling still seems to be improved
Mad Dog Tannen
Sep 12, 2015 12:48 AM
pfwel1977
Sep 10, 2015 02:16 PM
dantheman42
Sep 4, 2015 01:10 PM
Viczhou
Sep 2, 2015 07:55 PM
