Megan upper strut bar rattling
Just installed a Megan upper front strut bar, and my car is rattling everytime I'm not moving.
I had a generic one on before, and there were no problems.
I am thinking that the Megan one is lower, and is vibrating against an engine part.
I'm thinking I should add some washers under the strut bar mounts on the bolts to increase the height of the strut bar.
Not too sure though... any opinions?
thanks,
no intake though
i think it's rattling against the part thats above the engine.
what is that... the brake reservoir?
i'm probably going to put in some washers and see what happens
no intake though
Originally Posted by Victorious
thanks,
no intake though
no intake though
if it is the brake reservior/master cylinder that is rattling against it, i believe another member mentioned that there is a second mounting point for the reservior located just below the original location that gives enough clearance for the bar.
You can also wrap the reservior is a wrist band and tape the bottom to keep it on if that is what is happening. (That is unless you buy those overpriced reservior wrap things which are basically wrist bands for $40 more)
so have you looked upder the hood while its idling to see what is rattling.. other than that you wont be able to tell what it is hitting till a month or 2 down the road where you can see wear & tear from the 2 parts rubbing
sorry if this is old
i was having the same prob
the clutch cable resivour can be mounted lower on the bracket below and the knockin nose is from that silver tubing for the AC i just ziptied that off and the noise went away. Hope that helps
pfwel1977
Sep 10, 2015 02:16 PM
dantheman42
Sep 4, 2015 01:10 PM
