Upsizing Injectors
Old Mar 27, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
Upsizing Injectors
The only way the 7thgen civics can upsize their injectors is by getting emanage. Well the 6thgen civic can upsize their injectors with apexi v-afc.
I met a guy the other day, he has a 2000 Si with 310 injectors and v-afc...
why are we not able to? does 6th gen have fuel return system unlike 7thgen which doesnt!!!
Thanks guys
Old Mar 27, 2006
tfnaaf's Avatar
BLDNPSI Mod
why does the 7th gen HAVE use e-manage? To my knowledge you CAN use a vafc, just not recommended
Old Mar 27, 2006
BoostedVik's Avatar
ok, didnt know, people always say get rsx injectors and emanage!
thanks. why is it not recommended?
i'll rep ya later
Old Mar 27, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
emanage has whats called an injector correction factor. you put in what your stock injectors are and what you are changing them to and it calibrates them for you in order to tune more precise. The emanage is recommended over the vafc in both n/a and turbo due to the expanded tuning capability like ignition timing control and a broader range to tune your air and fuel mixture.
Old Mar 27, 2006
BoostedVik's Avatar
my original plan is for emanage with rsx injectors but no money so going for v-afc for few years. thanks
rep ya later
Old Mar 27, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
^^^emanage isn't that much more!
Old Mar 27, 2006
280zforce's Avatar
280zforce will become famous soon enough280zforce will become famous soon enough
rep ya later
i've got some RC Engineering 310cc injectors and new clips that should do yeah for cheap...$100 shipped.
let me know if u r interested...
AIM: s30zforce
Email: RuffRyder1103@comcast.net
Old Mar 27, 2006
andyman97's Avatar
Turbo Guru
The emanage injector correction factor is garbage, imo. You can only run an injector up to a certain size, then it turns on the check engine light due to the current being drawn for the map sensor to correct the injectors.
The AFC does the same exact thing. The benefit to the emanage is the ability to control ignition timing which is quite useful but you need real management if you want to make real power.
Old Mar 27, 2006
XSRCivic's Avatar
Agreed, the emanage can only correct to a certain size. Its working fine for me with 310 cc injectors. Not everyone can afford real management (AEM EMS). Hell, I wish I could.
Old Mar 28, 2006
BoostedVik's Avatar
i got my apexi v-afc for $180 compared to emanage and all the harness plus the injectors that would be some where around $550, thats the basic emanage 300 + dezod pnp harness 150 + rsx injectors ~ 100 = 550
not that close
AIM: s30zforce
yeah they are cheap, but i could these here , for $58
they are not RC tho
http://www.nolimitmotorsport.com/prod/SCIO310
i guess going with 310cc injectors with v-afc is ok,
this is what i got now,
tsi with t25 at preset 6psi
and v-afc untuned
Last edited by BoostedVik; Mar 28, 2006 at 08:46 AM. Reason: Automerged Doublepost
Old Mar 28, 2006
XSRCivic's Avatar
you still don't have anything to adjust ignition timing.
you need to read this thread.
EDIT: Keep in mind that this thread was made wayyy long before AEM EMS became available for our cars. If you want to go all out AEM EMS is truely the real way to go. You gotta pay to play.
Old Mar 28, 2006
BoostedVik's Avatar
yeah, aem ems is for real gear heads... i need more fuel thats all, not boosting the **** out of it... i did read that forum and thanks its good info, but the way i really but afc, emanage and aem ems. afc 0-6 psi, emanage 7-10psi, aem ems 11+ psi. i am at the 6 psi and i should go with afc in retard timing mode. its bad but it works for now. later on more boost and emanage will be required.
Old Mar 28, 2006
BoostedVik's Avatar
mainstream performance here in ga, i asked them how much for tunning the afc, they said one hour, which is $75. is it common for shops to tune a turboed car in an hour?
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
