Upsizing Injectors
Upsizing Injectors
The only way the 7thgen civics can upsize their injectors is by getting emanage. Well the 6thgen civic can upsize their injectors with apexi v-afc.
I met a guy the other day, he has a 2000 Si with 310 injectors and v-afc...
why are we not able to? does 6th gen have fuel return system unlike 7thgen which doesnt!!!
Thanks guys
Thanks guys
Originally Posted by tfnaaf
why does the 7th gen HAVE use e-manage? To my knowledge you CAN use a vafc, just not recommended
ok, didnt know, people always say get rsx injectors and emanage!
thanks. why is it not recommended?
i'll rep ya later
emanage has whats called an injector correction factor. you put in what your stock injectors are and what you are changing them to and it calibrates them for you in order to tune more precise. The emanage is recommended over the vafc in both n/a and turbo due to the expanded tuning capability like ignition timing control and a broader range to tune your air and fuel mixture.
my original plan is for emanage with rsx injectors but no money so going for v-afc for few years. thanks
rep ya later
rep ya later
rep ya later
let me know if u r interested...
AIM: s30zforce
Email: RuffRyder1103@comcast.net
The emanage injector correction factor is garbage, imo. You can only run an injector up to a certain size, then it turns on the check engine light due to the current being drawn for the map sensor to correct the injectors.
The AFC does the same exact thing. The benefit to the emanage is the ability to control ignition timing which is quite useful but you need real management if you want to make real power.
Agreed, the emanage can only correct to a certain size. Its working fine for me with 310 cc injectors. Not everyone can afford real management (AEM EMS). Hell, I wish I could.
Originally Posted by bOoStEd042dr
^^^emanage isn't that much more!
not that close
Originally Posted by 280zforce
i've got some RC Engineering 310cc injectors and new clips that should do yeah for cheap...$100 shipped.
AIM: s30zforce
AIM: s30zforce
yeah they are cheap, but i could these here , for $58
they are not RC tho
http://www.nolimitmotorsport.com/prod/SCIO310
i guess going with 310cc injectors with v-afc is ok,
this is what i got now,
tsi with t25 at preset 6psi
and v-afc untuned
Last edited by BoostedVik; Mar 28, 2006 at 08:46 AM. Reason: Automerged Doublepost
you still don't have anything to adjust ignition timing.
you need to read this thread.
EDIT: Keep in mind that this thread was made wayyy long before AEM EMS became available for our cars. If you want to go all out AEM EMS is truely the real way to go. You gotta pay to play.
yeah, aem ems is for real gear heads... i need more fuel thats all, not boosting the **** out of it... i did read that forum and thanks its good info, but the way i really but afc, emanage and aem ems. afc 0-6 psi, emanage 7-10psi, aem ems 11+ psi. i am at the 6 psi and i should go with afc in retard timing mode. its bad but it works for now. later on more boost and emanage will be required.
mainstream performance here in ga, i asked them how much for tunning the afc, they said one hour, which is $75. is it common for shops to tune a turboed car in an hour?
Bruce2
Sep 21, 2015 08:01 PM
