Short Ram Intake Physics / theory
Ok...I have read just about every thread on the anything to do with Intakes. So please don't flame..my fire suit expired.
Why is it that low end power is decreased while air intake is increased?
I fully understand the "purpose" of the stock airbox and how it keeps air stored for constant airflow...And I understand that our car is only going to suck as much air as allowed by the ECU. So no matter what the same amount of air is going into the chamber...right?
It blows my mind how low end power decreased, but higher rpms and highway speeds the shortram feels more responsive.
Can someone explain this without using the word velosity stack.
Thanks in advance!
Thanks in advance!
I'll use the word vaccuum then.
First of all, its not how much air the ECU lets in, its how much air your right foot lets in, and at the most, its an amount defined as how much volume the engine vac pressure can suck through a 63mm hole.
Short rams (all filter on a stick intakes) use a filter that is excessive for the amount of air the engine requires, it then has little restriction in it, which disperses the engine vaccum pressure over that enormous filter area, which has the effect of making the vac pressure lower, making it basically harder for the air to get sucked through the filter.
The car needs some backup or reservoir in the intake system to make low end power, which is why you see a lot of the higher end induction systems retaining airboxes or using huge expansion sections to maintain a volume of air that can be pulled through into the engine on demand. The engine can draw from available air (closer it is to the engine, the less sucking the engine has to do to get it, that then creates a larger low pressure spot because its a large space, and vacuum resupplies the chamber.
I don't really know the best way to put it in words... its all pressure related effects, its all sucking.
The better response is due to low restriction, but it also hinders low end power. No matter what, you're getting 1 HP.
I get it..That's a perfect explination...Thanks a lot!
So any recomendations as far as oem or Injen short ram? I have gone back and forward so many times on this battle. I think everytime my wife asks me what I'm doing I pretty much either putting the stock box back on or installing the injen...Sound is cool, but I want a little go for around town. Hwy speeds it works nice, but I get smoked at the traffic lights by other rice
loosescrew84
16
Aug 11, 2015 07:08 PM
Farticle69
Aug 6, 2015 08:02 PM
