Grille Mesh Install???
Old Feb 23, 2002
Cowboy's Avatar
Cowboy is an unknown quantity at this point
I tried duct tape, it lasted a week. I thought about zip ties but there is nothng to attach it too. Has anyone ever used Hundre Mile an Hour tape? Any suggesions?
Old Feb 23, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
zip ties?
Old Feb 23, 2002
waytooslow's Avatar
waytooslow is an unknown quantity at this point
i used 2 screws. one at each end. you cant see the screws unless you really look. the screws keep the mesh real tight and smooth its not wavey at all.[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG]
p.s. $160= apc coupe chrome, shipped to you.....
Old Feb 23, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
use zip ties, just have to drill small holes in the plastic of the bumper.
I did kinda the same thing, but I used like 14gague wire and just twisted it tight.
the screw idea seems like a good one too.
Good luck!
Old Feb 23, 2002
CivicPro01's Avatar
CivicPro01 is an unknown quantity at this point
What exactly is "zip ties"?? Thanks!!
Old Feb 23, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
Zip ties=zap straps
Potatos=Pototoes
Old Feb 23, 2002
Cowboy's Avatar
I cannot drill into the front bumper because it is fiberglass, it is very thin and a screw would most likely make it crack. I am not even going to try it.
Old Feb 23, 2002
waytooslow's Avatar
<< I cannot drill into the front bumper because it is fiberglass, it is very thin and a screw would most likely make it crack. I am not even going to try it. >>
what?? fiberglass huh?? hahahahahahahahah you idiot[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG]
Old Feb 23, 2002
speedyJB's Avatar
speedyJB is an unknown quantity at this point
lacingwire would work well!!!
Old Feb 24, 2002
Plastic man! Not fibre glass, its a Honda Civic, not a Corvette!![IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 24, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
Here's how I did mine. Get some stainless steel picture hanging wire. The braided stuff that comes in like 6' rolls. Unwind one strand of it and cut it to 18" lengths. Place the grill on, fold the strand of wire in half, push the two ends of the wire through the grill, making sure to catch one "wire" of the grill in the center. The center of the wire where it folds in half should be pulled tight up against the grill, then pass the two ends through the black part of the bumper and tie it tight from the back. The wire is completely invisible to the naked eye unless you get real close, and even then it takes a minute to find the spots where it's tied from. Not only that, but the wire won't rust, and with this method, you don't have to cut out the black part of the bumper because you're using it to tie onto to. Look at my ride to see how clean the grill looks.
Old Feb 24, 2002
Spider883's Avatar
9K Redline Owns U
try using a type of glue that drys clear that way if u want to take out the gril u just have to cut the glue
Old Feb 24, 2002
Cowboy's Avatar
Thanks for the info but, I do not have the stock bumper, I see what you are saying 2hondaz but i don't think it will work on my bumper, I will try it though.
Old Feb 24, 2002
Macko's Avatar
Macko is an unknown quantity at this point
should've fiberglassed the mesh to the bumper before installing it...[IMG]i/expressions/laugh2.gif[/IMG]
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Misfit2613
Jul 30, 2015 09:49 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
