fuse problem
Old Mar 2, 2006
shmik1's Avatar
fuse problem
so I get in my car and turn on my music and it starts for 3 seconds then stops...WTF? I knew right away both amps werent working, deck was 'fine,' so when i got home I checked over the remote wiring etc, then I tested my power wire just to be sure, well it was dead.
more testing, then i find the fuse isnt working, its not blown. just doesnt work.
swap fuses, problem fixed...
so my question is, what was wrong with the fuse, it has some white junk on it (inside on the metal piece) it looks like glue, couldn't say for sure if it was there before or for how long, but a new fuse works fine and heres a pic if u can see it.. hard to get a fuse pic...
if anyone knows what happened with this fuse, or why... let me know please.
fyi: fuse was used for atleast 2years and the car has been outside almost its entire life in IL weather. so anything from 90+ heat in the summer to negative temps in the winter. and sometimes weird temperature changes... 30+ degree changes within 12-24hours.
maybe this is a weather thing?
Old Mar 2, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
the air tight seal prolly became not air tight and the contacts oxidised
Old Mar 2, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
thats one of the downsides of ANL fuses. the fusible link could look fine but it'll still break the circuit. only way to test for sure is to test for continuity
Old Mar 3, 2006
shmik1's Avatar
ok i figured it was just something to do w/ it just getting old, which is good. atleast its not a real problem.
i just used a cheapy light up tester, did the trick for me.
thanks guys!
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
roverben
Jan 21, 2019 05:16 PM
beveragemp
May 25, 2015 07:11 PM
steveneddy
May 19, 2015 02:39 PM
