cant get shock off!!
Old Mar 1, 2006
Gabe Niemeyer's Avatar
Gabe Niemeyer is an unknown quantity at this point
Im putting new springs on my car and I got the front done, but now Im working on the back and i cant get the lower bolt loose. Its on so tight I tried a ratchet with a long pipe over it for leverage but i just cant get it to budge.
Would an air ratchet work??
Thanks
Gabe
Old Mar 1, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
is that long thick @ss gold color bolt? if so, yes, that was a pain in the @ss for me too lol.
what i did was i took a jack and pushed the brake assembly up a little, took a mallet and kept trying to hit it out. hope you have a partner in handy
goodluck
Old Mar 1, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
if you are using a 3/8" ratchet becareful if the tools arent craftsman/snap-on...my bro was doing an install with husky and the ratchet sheared....either use at least a 1/2" drive breaker bar(aka t-bar) or use air tools...you can rent tools from home depot
Old Mar 1, 2006
gipperkid's Avatar
gipperkid is an unknown quantity at this point
make sure you are turning the bolt and not the nut that's welded to the arm
Old Mar 1, 2006
pon55's Avatar
Thanks
Gabe
A good one will!
Old Mar 1, 2006
Ser1N's Avatar
EK Hatch
Ser1N is an unknown quantity at this point
Dont break it tho -_-, that will turn the world to hell
Old Mar 1, 2006
PunkingCivic's Avatar
I need TP for my bunghole
That would make the whole topic funny as hell!
Old Mar 1, 2006
no i know about the welded nut,
I rented a electric impact tool from Home depot and it wasnt strong enough,
Air is stronger but i dont have access to them.
Someone told me if you hold a torch to it, it will make it come loose a lot easier. Does this sound right?
Old Mar 1, 2006
Ser1N's Avatar
EK Hatch
If you use like anti sieze liquid spray and magnesium torch it will help it loosen up~
Old Mar 1, 2006
Yeah that sounds right. I had to do that for a header bolt
Old Mar 1, 2006
D17thgen's Avatar
or some lubricant (wd-40)
also, it should be an metric size, not standard correct? i always thought forgein cars used MM while american/domestic used standard size (inch)
Old Mar 1, 2006
pon55's Avatar
The torch will burn up the bushing!
Rent a 3/4 drive breaker bar and socket, with pipe on the end it will loosen or break!
Old Mar 1, 2006
that is our cars are mostly/if not 100% metric..however if metric doesnt fit right but standard does use that...sometimes wrongs bolts get put on ......you the the tool that makes the job easiest
Old Mar 1, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Don't use WD-40, use Liquid Wrench or something. WD-40 isn't rust remover, and it eats rubber.
That bolt shouldn't be so hard to get out, so something is seriously messed up. Are you sure its not spinning in the bushing (which seems to be a common problem)?
Try the impact gun, but don't torch it until you've tried ABSOLUTELY everything else.
Old Mar 1, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
you don't have to "torch it" you can hook up a hair dryer and air blow it hot.
Old Mar 1, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
And in the end... Its gonna come down to elbow grease. I too have had the same prolem with the rear. I even had an air gun on it and it wouldnt even budge it. In the end i used my foot. It was the thing that moved it and it still took forever.
Old Mar 1, 2006
pacopepe132's Avatar
pacopepe132 is an unknown quantity at this point
that would take you at least a month to get it loose.your best bet it's an air impact wrench or gun.
Old Mar 1, 2006
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
I had the exact same problem last week when i was installing the rear springs on my g/f's 01. It was the driver side. The nut that was welded, actually ended up breaking the weld off, and had to take an air chisel and actually cut the bushing out. But i was also putting new koni's in and we didn't need the old bushing. Just go rent a 1/2" impact
Old Mar 4, 2006
silver_surfer's Avatar
Pretty friggin old-school member
silver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of light
I had this issue 2 weeks ago.. I finally gave up and took it to a shop.. they had to cut my shock off to get the bolt out.. it was rediculous
Old Mar 4, 2006
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
I had the same issue with my drivers side rear, lower, shock bolt. I think they used too much torque installing the stock shocks. I finally used the old torch, heated up the nut, used wd-40 cause i had new AGX in hand, and eventually got it off. I too was dreaming of taking the dam thing into a shop to let them cut it off. But I got it!!
Old Mar 9, 2006
Well i took it to a guy i knew and gave him 20 bucks. He torched it for quite a while. It probably took him at least a half hour, but they finally came loose.
I installed my new springs and struts and they work great.
Thanks for all the help guys
Gabe
Old Mar 9, 2006
pics, pics, pics
Old Mar 9, 2006
pon55's Avatar
Gabe
Thats why were here, just to help
(or at least try)
Old Mar 9, 2006
MajinB's Avatar
ok i did mine tonight. put some snow gloves on. take the the 5mm hex key and WD40 it and the 17mm nut on the strut. take the 17mm wrench, hold it down sideways, on the ground. with the snow gloves on, make sure they are thick, pull hard as ****. hammer a little, pull some more. key the hex key still yo. i used the hair dryer, wd40 and hammer. it worked after about 1 hour.
Old Mar 10, 2006
Gabe
Way to go.
Old Mar 10, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I put my ratchet on the bolt, then placed a jack under the ratchet, and after a couple pumps it came undone.
Wow, that last sentence sounds really dirty if you think about it...
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
