cant get shock off!!
Im putting new springs on my car and I got the front done, but now Im working on the back and i cant get the lower bolt loose. Its on so tight I tried a ratchet with a long pipe over it for leverage but i just cant get it to budge.
Would an air ratchet work??
Thanks
Gabe
Thanks
Gabe
is that long thick @ss gold color bolt? if so, yes, that was a pain in the @ss for me too lol.
what i did was i took a jack and pushed the brake assembly up a little, took a mallet and kept trying to hit it out. hope you have a partner in handy
goodluck
goodluck
if you are using a 3/8" ratchet becareful if the tools arent craftsman/snap-on...my bro was doing an install with husky and the ratchet sheared....either use at least a 1/2" drive breaker bar(aka t-bar) or use air tools...you can rent tools from home depot
Thanks
Gabe
Thanks
Gabe
I need TP for my bunghole
Originally Posted by gipperkid
make sure you are turning the bolt and not the nut that's welded to the arm
no i know about the welded nut,
I rented a electric impact tool from Home depot and it wasnt strong enough,
Air is stronger but i dont have access to them.
Someone told me if you hold a torch to it, it will make it come loose a lot easier. Does this sound right?
Originally Posted by D17thgen
or some lubricant (wd-40)
also, it should be an metric size, not standard correct? i always thought forgein cars used MM while american/domestic used standard size (inch)
that is our cars are mostly/if not 100% metric..however if metric doesnt fit right but standard does use that...sometimes wrongs bolts get put on ......you the the tool that makes the job easiest
Don't use WD-40, use Liquid Wrench or something. WD-40 isn't rust remover, and it eats rubber.
That bolt shouldn't be so hard to get out, so something is seriously messed up. Are you sure its not spinning in the bushing (which seems to be a common problem)?
Try the impact gun, but don't torch it until you've tried ABSOLUTELY everything else.
I hope I offend you... Get mad
And in the end... Its gonna come down to elbow grease. I too have had the same prolem with the rear. I even had an air gun on it and it wouldnt even budge it. In the end i used my foot. It was the thing that moved it and it still took forever.
Originally Posted by MajinB
you don't have to "torch it" you can hook up a hair dryer and air blow it hot.
Pretty friggin old-school member
I had this issue 2 weeks ago.. I finally gave up and took it to a shop.. they had to cut my shock off to get the bolt out.. it was rediculous
I had the same issue with my drivers side rear, lower, shock bolt. I think they used too much torque installing the stock shocks. I finally used the old torch, heated up the nut, used wd-40 cause i had new AGX in hand, and eventually got it off. I too was dreaming of taking the dam thing into a shop to let them cut it off. But I got it!!
Well i took it to a guy i knew and gave him 20 bucks. He torched it for quite a while. It probably took him at least a half hour, but they finally came loose.
I installed my new springs and struts and they work great.
Thanks for all the help guys
Gabe
Gabe
Gabe
Gabe
(or at least try)
Drunken Master-7thgen Ninja
ok i did mine tonight. put some snow gloves on. take the the 5mm hex key and WD40 it and the 17mm nut on the strut. take the 17mm wrench, hold it down sideways, on the ground. with the snow gloves on, make sure they are thick, pull hard as ****. hammer a little, pull some more. key the hex key still yo. i used the hair dryer, wd40 and hammer. it worked after about 1 hour.
Gabe
Gabe
Way to go. Joined: Feb 2006
I put my ratchet on the bolt, then placed a jack under the ratchet, and after a couple pumps it came undone.
Wow, that last sentence sounds really dirty if you think about it...
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
