where the diy hyperblinker for the ex
Old Feb 20, 2002
insan's Avatar
insan is an unknown quantity at this point
i was trying the diy hiperblinker. then realized it was for the lx not the ex. i tryed it at first it all the blinker did was stay on....[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 20, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Here is the link for the DIY. He did do it on his lx, but it will work on the ex. It doesn't matter. The only thing that matters is if your car is a sedan or a coupe. No one has figured it out for the sedan yet. Just follow his directions because they are very good. I did this mod myself before on my own (i have an ex) and it works perfectly. Just make sure you use 133k resistor because anything lower than that is just too fast.... hope that helps...
Old Feb 20, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
quick and east 5 min mod
Old Feb 21, 2002
Vinas's Avatar
Vinas is an unknown quantity at this point
Is there any consensus on what resistor value to use for roughly 2x blinking speed?
Old Feb 21, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
what watts should we use (1/2 or 1/4?) I bought a 100k ohm resistor and 1/2 watts. Is that gonna be too fast? And where can I buy 133k ohm resistor? I tried Radioshack but they got none. Only 100k then 200k. Also at 1/2 and 1/4 watts. Help
Old Feb 22, 2002
Mokushi's Avatar
I bought my 133k ones at radio shack for like $0.75. I still have the rest of the package somewhere. I'll check the wattage when I get home...
Old Feb 22, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
use ¼watt being the whole blinker relay is very low current... the ½watt will work too, just it's a bit bigger and might not fit inside the housing.
Finding a 133k resistor at radio shack can be near impossible. I eventually had to go to a huge electronics store that carries 10x the stock of radio suck, and I still didn't find a 133k resistor. They only had 150 and 120.
FYI, when you put 2 resistors in parrellel, like my DIY says, you are basically lowering the totall resistance going through the circut. I wouldn't advise this, but it's the same as taking off the 133k resistor, and replacing it with like a 66k resistor.
Old Feb 22, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
I have the 6x blinker. it takes only a few minute to install.
Old Feb 23, 2002
VTecnology's Avatar
will the 1/2 100k resistor be too fast? If so, how fast per second?
Old Feb 23, 2002
ph0ng's Avatar
If I were ready to sit down and do some calculations, I could tell you the exact blink rate... but I'll just tell you what it looks like.
The lights didn't have enough time to dim half way before turning on again.
They were almost to a point that they were on solid.
you can always play around and see what you get.
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
