Amp with lower wattage than the sub
Old Feb 14, 2006
hexed's Avatar
The black russian
hexed is an unknown quantity at this point
Hi, I have maybe very stupid question but you gotta start somewhere
Ok so i got a 1000 watt sub and and 600 watt amp
question is if I hook it up for now to the amp that is lower wattage
will it burn out? Can i keep amp for now at like 80% of its power?
Any suggestions except for spending more $$ for new amp?
Thanks in advance
Old Feb 14, 2006
jttegx's Avatar
OMNES AD UNUM
*assuming the amp is set on the proper settings* no, the amp will not be or harm any damage by just hooking it up to a sub that can has more potential.
you can run that amp as hard as you want because you're only underpowering the sub with it. some subwoofers dont like being underpowered (IE: kicker solobarics) so they tend to not sound as expected. but that doesnt mean the sub still cant blow. remember that distortion causes speakers/subwoofers to blow, not overpowering. u can take an 400watt amp and hook it up to a 1000watt sub and still blow it if u had the bass boost and gains on max
Old Feb 14, 2006
dtox666's Avatar
dtox666 is an unknown quantity at this point
1000w RMS?
or
1000w max?
Old Feb 14, 2006
MegaHurtz's Avatar
Originally Posted by dtox666
1000w RMS?
or
1000w max?
Does it matter?
It'll be fine either way, assuming that the amp is set correctly.
Old Feb 14, 2006
hexed's Avatar
The black russian
1000w RMS?
or
1000w max?
can you explain whats the difference between two?
btw, thx all for help.
Old Feb 14, 2006
hdave's Avatar
hdave is an unknown quantity at this point
rms is the real power
max is just some BS they pulled out of their ***
Old Feb 15, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
RMS Power is bogus...there is no such thing..
Old Feb 15, 2006
MegaHurtz's Avatar
explain...
Old Feb 15, 2006
joescivic02's Avatar
Abercrombie and Fitch
Devani what are you talking about? Obviously you haven't been into car audio long. And people, this topic has been covered many times. Use that search button and itll save threads being made and locked. How is RMS bogus? How isn't there such thing? How about you go to crutchfield or some sort of other source and type in RMS.... youll get the results of root man square. This means a continous wattage pumping out of an amp....you should follow the RMS guidelines when buying a sub and amp...
Old Feb 15, 2006
LudlamTheory's Avatar
i boogie for the raindrops
if he runs the amp hard, he will induce distortion, and will kill the sub
subs like things?
i was under the impression that they were inanimate objects
kidding... but seriously, all he will get is a loss in output. if there is indeed a change in sound at higher power it is because at higher excursion, most subwoofers with a standard single gap motor topology lose linearity and put out more distortion.
now you may say, but i dont like distortion, it sounds bad...
well, ever met some punk kid that think his sony's sound better than a JL w7?
i have
its a thing of taste.
overpowering a sub can indeed blow it too... overexcursion, bottoming out, separation of the spider, tearing off surrounds, etc...
Old Feb 15, 2006
Originally Posted by MegaHurtz
Does it matter?
cmon mr hurtz...
you should know of the many many many drivers rated at 200 rms/1000 max
Old Feb 15, 2006
root mean square = average, not continuous.
Old Feb 16, 2006
hexed's Avatar
The black russian
LudlamTheory, is there some kind of basic write-up on sound system install.
I want to get it right from the first time =)
Old Feb 16, 2006
the top of this forum has a thread with links in it....
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
