My alignment specs....
Old Feb 12, 2006
goodtimes's Avatar
Question My alignment specs....
Left Front
Actual Camber -.50
Actual Caster 2.75
Actual Toe 0.19
Right Front
Actual Camber 0.04
Actual Caster 2.50
Actual Toe 0.19
Left Rear
Actual Camber -1.25
Actual Toe 0.18
Right Rear
Actual Camber -0.44
Actual Toe 0.15
Alingment done with megan coilovers at Big O tires, does it look good
Old Feb 12, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I don't like it.
Front camber should be 0. Rear toe is ok there, but your camber is awefully uneven.
Old Feb 13, 2006
goodtimes's Avatar
yeah thats what i was thinkin to i can see the camber diff in the tires,
how about my toe in the front?
Old Feb 13, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
alignment specs should be in a specific range. If your car is lowered you will definitely need a camber kit for a perfect alignment. The alignment specs on your car are off. Front specs should be: camber -0.8 to 0.8, caster 1.2 to 3.2, and toe -0.12 to 0.12, but if your car is lowered most places will only set the toe because lowering the car max's out the camber. the rear specs should be: camber -1.5 to 0.0 and toe 0.04 to 0.16 caster has no adjustment. You should take it back and have them redo it.
Old Feb 13, 2006
goodtimes's Avatar
the guy told me that they could not set the toe all the way b/c the tie rod were you adjust the toe he said it was maxed out, so i was thinking rase the ride hight to like 1 finger gap b/c now i tuckin my fronts
Old Feb 13, 2006
Jap-Euro Fusion
^^^ well that sounds like it would be a wise idea. With the car that low, you've got no travel anyways.
Old Feb 13, 2006
goodtimes's Avatar
but with the megan coilovers you can adjust the ride hight with out changing shock travel so that should not matter right.
Old Feb 13, 2006
Jap-Euro Fusion
The car only goes so low before you start putting tires through the fenders or ripping the tie rods out of the steering box. You may not hit the bump stops because you'll hit something else first. There is such a thing as TOO LOW and not too many people seem to realize that. You're already out of tie rod travel with out a set alignment, which means you've got no room to spare, you hit a bump, they've got no where to go, not to mention you start putting the frame into play with the tie rod angle, the chance is there that you basically bind the tie rod on the frame and snap it in half.
Old Feb 15, 2006
buckshizzo's Avatar
just buy a camber kit and raise it up a bit. got my camber kit off ebay for $80.00 shipped...definitely worth it in the long run.
Old Feb 15, 2006
goodtimes's Avatar
the coilovers i got come with a camber plates on it so no need for a camber kit...
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
