resonator...with or without???
Old Feb 18, 2002
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I recently got my muffler replaced and at the same time got the 21/4 pipe from the cat-back without the resonator. However, someone told me that it's better to have a resonator cause I need back pressure for some quality HP. Is it true? Which way is better for better performance? Car sounds sweet without it though!!!
Old Feb 18, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
since you have 2.25" pipes, you'll be fine. as long as u didn't go out and get 3" pipes, you don't really have to worry about backpressure
Old Feb 18, 2002
CUE2k1's Avatar
cool, thanks man....
Old Feb 18, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Well, it all depends. How many time did the guy bend your pipe? all those bend contribute to your back pressure and how much you get. if you really want 2¼ piping you should get 2½ piping with the pipe going above the control arm. if you really wanted no back pressure(turbo apps) you have your piping come straight through right under your lower tie bar and have one bend take it to the opening. IF you are wondering how I got the ½¼: using the keypad hold alt and type 171 or 171. Its the ASCII number for characters.
Old Feb 19, 2002
CUE2k1's Avatar
I think the dude set it up like the factory pipes. Bent it quite a bit.... Will it harm the HP if I add an aftermarket resonator?
Old Feb 19, 2002
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
i did mine with 2 ½ and i gained hp but lost torque but i'm doing forced induction soon so i dont care!
Old Feb 19, 2002
CUE2k1's Avatar
forced induction??? Sorry man, I'm kinda new to this!! [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 19, 2002
avenger's Avatar
avenger is an unknown quantity at this point
aah, the back pressure myth continues....
