Question 9006 hid shied
Old Feb 6, 2006
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
Question Question 9006 hid shied
If I can get the guys @ capers electronics to make a 9006 hid shield how many of u guys will buy it. I just need some numbers that i can throw at them. I will know later on. If it is possible to get them to make that shield.
https://www.casperselectronics.com/M...Category_Code=
Old Feb 6, 2006
aznrocka's Avatar
aznrocka is an unknown quantity at this point
interested
Old Feb 6, 2006
veloz's Avatar
veloz is an unknown quantity at this point
do you guys already have HIDs?
I have 9006's installed in my 05 coupe, without shields obviously......do we really need shields for them?
Old Feb 6, 2006
DAQIUN's Avatar
There No One Else Who Would Like To Have A 9006 Hid Shield Instead Of Retrofiting A Projector?
Old Feb 6, 2006
MegaHurtz's Avatar
Are you sure they can make it?
How hard would it be to install?
Old Feb 6, 2006
ragingSPAM's Avatar
I just burnt my tongue
the 9006 housing on the 04-05s actually provide for a lot less glare than the 01-03s...the single beam helps a lot...most plug and play kits for the 04-05s will have little glare...instead of glare shields i suggest just getting some rebased D2S bulbs (ebay, www.hidexpert.com , hid planet) cuz on the 04-05s glare isnt that bad with the stock shield
Old Feb 7, 2006
DAQIUN's Avatar
So how would i get my tsx bulbs, wiring harness, and blasts to work then.
Old Feb 8, 2006
ragingSPAM's Avatar
you can always sent them into hidexpert.com i asked him and he says its $35 shipped for getting 2 d2s/d2r bulbs rebased to 9006 so u can just plug them into ur stock headlight...and you can put on a 9006 connector onto the harness and plug it into the balast...i think hidexpert also can make custom connectors...i was thinking of getting thier kit but im broke at the moment so i just asked a buncha questions
Old Feb 9, 2006
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
how good would the kit from hidexpert.com be, $298 for rebased bulbs doesnt seem to bad and they come with reputable (i think so) ballasts
Old Feb 10, 2006
ragingSPAM's Avatar
the things they sell are OEM equipment which they get from Denso/koito which are suppliers for Lexus and toyota and they use OEM phillips and osram bulbs which they use in all OEM cars equiped with HID's...they have a machine rebase the bottom of the bulb with a 9006 ring so it will fit in the slot of a 9006 headlight reflector...i think they can also make u a custom connector for the 9006 so u can connect the stock harness to the balast...i got this info from them when i emailed them
Old Feb 10, 2006
Super Member
hmmm seems like buying rebased will offer you the same quality equipmentas oem, but nearly the same output as a generic plug and play kit
Old Feb 10, 2006
ragingSPAM's Avatar
so it will last longer but output would be good depending on what bulb style u have...xenondepot has oem kits too but they're a lot more expensive
Old Feb 10, 2006
mrDFWmechanic's Avatar
www.hidexpert.com has the same stuff for their kits they sell
Old Feb 10, 2006
Super Member
well i have an 04
Old Feb 12, 2006
ragingSPAM's Avatar
u can get a rebased 9006 kit for a little bit more than a cheaper plug and play kit for your car from www.hidexpert.com ....thats what i would do
tuvok
Sep 25, 2015 03:13 PM
junkyardguy
Sep 2, 2015 06:07 PM
totravska
Aug 30, 2015 12:02 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
