Question 9006 hid shied
If I can get the guys @ capers electronics to make a 9006 hid shield how many of u guys will buy it. I just need some numbers that i can throw at them. I will know later on. If it is possible to get them to make that shield.
https://www.casperselectronics.com/M...Category_Code=
I just burnt my tongue
the 9006 housing on the 04-05s actually provide for a lot less glare than the 01-03s...the single beam helps a lot...most plug and play kits for the 04-05s will have little glare...instead of glare shields i suggest just getting some rebased D2S bulbs (ebay, www.hidexpert.com , hid planet) cuz on the 04-05s glare isnt that bad with the stock shield
you can always sent them into hidexpert.com i asked him and he says its $35 shipped for getting 2 d2s/d2r bulbs rebased to 9006 so u can just plug them into ur stock headlight...and you can put on a 9006 connector onto the harness and plug it into the balast...i think hidexpert also can make custom connectors...i was thinking of getting thier kit but im broke at the moment so i just asked a buncha questions
the things they sell are OEM equipment which they get from Denso/koito which are suppliers for Lexus and toyota and they use OEM phillips and osram bulbs which they use in all OEM cars equiped with HID's...they have a machine rebase the bottom of the bulb with a 9006 ring so it will fit in the slot of a 9006 headlight reflector...i think they can also make u a custom connector for the 9006 so u can connect the stock harness to the balast...i got this info from them when i emailed them
www.hidexpert.com has the same stuff for their kits they sell
u can get a rebased 9006 kit for a little bit more than a cheaper plug and play kit for your car from www.hidexpert.com ....thats what i would do
junkyardguy
Sep 2, 2015 06:07 PM
totravska
Aug 30, 2015 12:02 AM
martinsmartin
Aug 15, 2015 07:34 PM
