building up the d17 vtec..
Old Jan 19, 2006
wborocivex's Avatar
wborocivex is an unknown quantity at this point
okay, so bolt-ons.. def. dont do much for teh civic as we all know.. but, i wanna know what all goes into "building" a motor up, as in,, if i took it to a shop and said, okay, make my motor better, what can they all do? camshaft, camgears, but what else? and how much will it run me up? and is it worth it?
Old Jan 19, 2006
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Originally Posted by ***** Fn FBM 85
not worth it.
For the money it takes to build a N/A d17 you could have a stock k20 swap that would be 1000000000x more reliable. and put out way more Tq. and rev wayyyyy higher
Old Jan 19, 2006
smk's Avatar
smk
smk is an unknown quantity at this point
I just got my civic, and I was also thinking about modding it... but I just scrapped the idea of modding that engine, and saving for something big after the warranty is over (K20a3, yummy). I would suggest doing work to the suspension, I'm having alot of fun with twisties after I lowered my car, while still using the stock engine. Just my opinion though!
Old Jan 19, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
not worth it.
Old Feb 8, 2006
jdm_es2's Avatar
jdm_es2 is an unknown quantity at this point
Dezod Turbo Kit
Old Feb 8, 2006
genexrocket's Avatar
turbo, yum
Old Feb 8, 2006
TQ_'s Avatar
TQ_
TQ_ is an unknown quantity at this point
Most swap shops, unless you are doing the word yourself you can get a K20A2 for about 500 dollars more than the K20A3. The K20A2 will put out 200 HP compared to the A3's 160 HP. That is how it is here, don't know about where you live.
Old Feb 8, 2006
Michalo187's Avatar
Abortion Survivor
^^^ It also depends what he wants cause he could get the k20a3 and boost it or k20a2 all motor or even boost that but would be harder i believe because of its high compression
Old Feb 8, 2006
Spracto's Avatar
Spracto is an unknown quantity at this point
i'd like to swap an A3 in just cause i don't wanna have to use premium gas but for the money its still more worth it to get the A2 with real vtec.
Old Feb 8, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
heh wtf? ... only $500 more dollars than a K20A3?
that's either a REALLY REALLY cheap K20A2 or a REALLY REALLY expensive K20A3 ...
A3 engine swaps go for about $1500-2000 ... A2 swaps go for about $3500
Old Feb 9, 2006
turboengnr's Avatar
DONT PANIC
theres a lot that goes into building a motor. I am currently building my D17A1 motor. Should be assembled here within the next week. Then in the car within the month.
First off, you have to buy the parts.
pistons
rods
piston rings
wristpins (usually come with the pistons)
sleeves
cam
valve springs
valve spring retainers
main journal bearings
thrust washers
rod bearings
oil pump
water pump
timing belt
rear main seal
oil pan gasket
water pump gasket
oil pump gasket
cam seals
valve cover gasket
head gasket
intake manifold gasket
exhaust manifold gasket
head studs
Then you have to pay for the labor for.....
removal of the motor
disassembly of the motor
flywheel balancing
crank balancing
cylinder hoaning
block decking
knotching cylinder walls to clear rods
milling pistons to fit rods
micropolishing the crank
clearancing bearings
assembly of the short block
disassembly of the cylinder head
Porting the cylinder head
valve job
lapping the valves
assembly of the long block
installation of the motor
after all of this, i can guarantee you that with a good tune my motor will be just as reliable as a K20 swap. Its just mine will be made for boost and putting out more way power and torque than any stock K20
Dave Brabant
20
Oct 6, 2015 12:44 AM
