Turbo Kit
Old Jan 18, 2006
kingklay's Avatar
kingklay has a little shameless behaviour in the past
Turbo Kit
im quite new to the tuner world here so i was wondering if this is a good turbo kit:
Garrett T3/04 Turbo, brand new - $900
* TiAL 38mm wastegate, brand new - $280
* GReddy RS BOV, brand new - $260
* GReddy emanage, brand new - $480
* GReddy pressure sensor, purchased used - $90
* GReddy ignition harness, brand new - $60
* GReddy injector harness, brand new - $60
* Dezod complete PnP wiring harness, wired for emanage ultimate - $120
* RSX injectors, purchased used - $120 Dibs to BigE19
* Johnny Race Car FMIC, brand new - $340
* SF turbo ELM, purchased lightly used - $675
* Max Rev down pipe for T3, brand new - $175
* TurboXS Manual Boost Controller - $100
What other parts would i need for this kit to complete if any
and what roughly would the price for install and tuning cost?
i have a 2002 civic lx.....i know i know i should have bought the SI
thanks in advance
clayton
Old Jan 18, 2006
turboengnr's Avatar
DONT PANIC
you have to do some more research....
why buy a PnP harness for an emanage ultimate, if you bought a normal emanage?
Why buy the ignition and injection harnesses if you are buying the PnP harness?
What the hell is an SF ELM? Are you talking about their FMU unit? If so, why the hell would you need the emanage and RSX injectors?
What manifold are you going to use? If you are using the Max-rev downpipe, you have to use a max rev manifold. Manifolds and downpipes are not usually interchangable.
Old Jan 18, 2006
red_sun's Avatar
Boost is so good make you wanna slap ya mamma
red_sun is on a distinguished road
I think SF ELM = Stafford fabrication equal length manifold.
turboengnr is right why are you buying a plug and play harness for an emanage ultimate when you have a normal emanage and I didn’t know Dezod even sold a PnP harness for emanage ultimate I looked on their website and I didn’t see it? Also the reason you buy a PnP is so you don’t have to wire anything it already has the Main, Injector & Ignition harnesses wired in that’s why it’s a PnP harness so you only need to buy pressure sensor and the PnP harness for normal emanage.
You’re going to probable need custom intercooler piping since you’re using a sf manifold and a Johnny racecar intercooler and the Max Rev down pipe might not even work with the sf manifold.
Some other things off the top of my head you need are oil Lines, fittings for oil lines, couplers for intercooler pipes, and a air filter. Some things you might want are a boost gauge, Colder Spark Plugs, more free flowing exhaust system.
I know I might be forgetting some things but that’s all I could think of for now also you might want to consider buying a complete kit, because you roughly have about $3330 in cost already for the stuff you want/need and you will still need to buy more and that would put you around the same price range as a complete kit from somewhere like Dezod and you know it should all work together.
Installation should be between $200-$1500 and tuning should be between $150-$800
Old Jan 18, 2006
kingklay's Avatar
Turbo
This is part of my research "turbo." thats why i havent bought this kit yet. like i said im brand new with this whole turbo thing, good thing i asked because i dont even know wtf half these parts are.
hes also taking $1000 less than what the total price is. sooo could you guys list for me what parts are useless.
oh and i do have an aftermarket exhaust system already(rs*r exmag)
thank you very much for you help
clayton
Old Jan 18, 2006
dezod's Avatar
7thgen Power Maker
clayton
Save the $$ on the SF EL manifold. If you going to spend $650 on a cheated and fudged cut mild steel manifold that flows like crap, spend an extra $100 and get our EL RACE V1 Manifold for $750.
http://dezod.com/pd_dezod_motorsports_equal_length.cfm
BTW, some corrections on your pricing. We have TIAL 38mm gates cheaper:
http://dezod.com/pd_tial.cfm
E-Manage: $299
http://dezod.com/pd_greddy_emanage_systemmain.cfm
BOV central all under your price:
http://dezod.com/cat_universal_bovs.cfm
If you buy our PnP, you do not need to supply the harnesses. (Includes Main, Injector & Ignition)
http://dezod.com/pd_emanage_plug_and_play.cfm
We could probably build you a real nice BAR & PLATE intercooler of 28"W x 3.5"D x 7"H for the same price as the Johnny RACE CAR I/C
Some manual boost controllers
http://dezod.com/cat_manual.cfm
Old Jan 18, 2006
Havok2k1's Avatar
Wicked Pissah Admin
check the custom turbo kit thread in the turbo FAQ, all your answers are there.....
Old Jan 18, 2006
tfnaaf's Avatar
BLDNPSI Mod
HERE is prolly where you should start your reading, followed by EVERY link...HERE. May i also suggest a good book called Maximum Boost: Designing, Testing, and Installing Turbocharger Systems it has some VERY good info
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
