omg!!!
Old Jan 8, 2006
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
omg!!!
hey guys. today i looked underneath my civic just to check if theres nothing wrong that i should know about. so i looked at my rear camber kit and everything is fine, then i move on to the exhaust. first, i was surprised at the fact that the muffler vibrates like crazy when on idle. second, i started checking the exhaust piping and i found two holes, one in each welding spot of the piping and i could see water dripping from both of the holes. i dont think thats normal. i'll have to get it rewelded for sure. what do u guys think?
Old Jan 8, 2006
HondaLuver's Avatar
Its a celebration bitches!
yup...
Old Jan 8, 2006
MBison's Avatar
does anyone have any INTELLIGENT response?
Old Jan 8, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by HondaLuver
yup...
haha he called you dumb.
Old Jan 8, 2006
MBison's Avatar
whatever u want to call it. response 'yup' is useless to me. thank u very much.
Old Jan 8, 2006
7thGenerasianCivic's Avatar
newbie owned TEmo! hahahhaahah
Yes, get it rewelded, 'water' is just condensation **** from the exhaust fumes... that's normal but the holes are not.
Old Jan 9, 2006
amhtown01's Avatar
yes sir, it seems as if you do indeed have to get your exhaust piping rewelded. Like Alan said, the water is just the condensation from the exhaust fumes.
I find it was easier to say "yup" to your, "....i dont think thats normal. i'll have to get it rewelded for sure. what do u guys think?" comment.
Old Jan 9, 2006
MBison's Avatar
true. what about the muffler vibrating? it shakes my whole rear bumper..
Old Jan 9, 2006
amhtown01's Avatar
is it a stock exhaust u have?
if its after market or what not just take it to an exhaust shop and they'll weld some brackets to hold ur exhaust still, thats what i recently did with mine. stopped vibrating
Old Jan 9, 2006
RHCP0801's Avatar
did you check if the support hangers were in tight and if they were all welded on tight??
Old Jan 9, 2006
MBison's Avatar
its a magnaflow catback. it already had a customized piping done when i bought it. it hangs by the rubber mounts, its not welded to the chasis.
Old Jan 9, 2006
MBison's Avatar
im going to check that out tomo. thanks.
Old Jan 9, 2006
RHCP0801's Avatar
the hangers are welded onto the muffler, are those good?
Old Jan 9, 2006
MBison's Avatar
yes it is. the whole magnaflow canister is just shaking really bad when on idle.
Old Jan 9, 2006
RHCP0801's Avatar
it might be a problem with the hangers cause thats what usually supports the muffler and keeps it from shaking.
Old Jan 9, 2006
MBison's Avatar
do u think i should get the hangers welded to the chasis?
Old Jan 9, 2006
RHCP0801's Avatar
na i dont think so, they should be good in the rubber holders that its supposed to be in, just check it out tomorrow and just like hold it or touch different spots of it and see what stops it from shaking, with like pot holders on or something hahahah cause its hot, thats what i wear when i touch my hot exhaust
Old Jan 9, 2006
MBison's Avatar
Thumbs up
haha, fo sho man i will take a closer look on that muffler. meanwhile i will prolly take it to a mufflershop tomorrow. thanks, bud.
Old Jan 9, 2006
RHCP0801's Avatar
no problem man, i just got the skunk 2 exhaust put on the other day and it was hitting the frame of the car by the mid pipe and it was rattling so loud, i was able to feel it through the shifter and armrest and everyone who got in my car was like wtf is that noise, yea it was that loud. I had my friend who put it on check it out and he had to heat up the midpipe and angle it down so it wouldnt hit, pain in the *** but it was worth it, man that exhaust is deep sounding and loud as hell....but anyway good luck with the exhaust man
Old Jan 9, 2006
born2xLr8's Avatar
If the shop welds brackets from the muffler to the chassis, won't all the vibrations be transfered to the body. I'd be more annoyed at feeling the vibrations through the car than just knowing my muffler is shaking. That's why the hangers are rubber after all. I believe there are stiffer ones made from plastic that will keep the muffler still while absorbing the vibration.
I also have the magnaflow catback and mine did the same thing in the beginning. It shakes on the rubber hangers because it's heavier. I took the ghetto route and used huge zip ties to compliment the factory rubber hangers. That worked for me. It stiffened the mounting points and stopped the muffler shaking. Not sure how much stiffer hangers cost. See what a shop has to say.
Old Jan 9, 2006
MBison's Avatar
yea guys. i went to a local muffler shop and the guy fixed the piping. he also welded 2 brackets to the chasis and used 4 zip-locks to hold the bottom of the bumper that meets with the muffler up, so now i dont feel any noise and my bumper dont vibrate anymore. finally the muffler moves freely. the guy was cool and charged me only $20.
Old Jan 16, 2006
pantsmcgee's Avatar
pantsmcgee is an unknown quantity at this point
nope its just magna flow i had the same thing with mine and for some reason it just seems to shake the heck out of your car at idle speeds i believe that it has something to do with frequency of the ehaust note at idle
Old Jan 16, 2006
MBison's Avatar
read above.
Old Jan 17, 2006
eyegiant's Avatar
eyegiant is an unknown quantity at this point
YOU DON'T WANT TO WELD THE EXHAUST SYSTEM TO THE CHASIS, CAUSE THE EXHAUST NEEDS SOME PLAY.
Old Jan 17, 2006
MBison's Avatar
thats right
Old Jan 19, 2006
NytRyder2k2's Avatar
Bay Area
yup.
Solo Flow
Oct 4, 2015 07:52 AM
CarbonFly
Mar 12, 2003 11:49 AM
iceman
South Cali
Sep 16, 2002 01:13 AM
Booohahaha
Mar 28, 2002 11:08 PM
