Is my car overheating?
Old Jan 4, 2006
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
About a week ago my matinence required light started flashing when I turned on my car (I know this means nothing), however once my car finally got to its running temperature I noticed that its getting a little higher each day. As of a few days ago this is what it was at:
today it is exactly on the half way mark (maybe just a hair more). Idk whats up with my car? I havent been running it hard at all lately, I've actually been taking it easy. I dont think its my oil because I changed it no more than 1k miles ago, so Im stumped. Any ideas guys?
Old Jan 4, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
checked your coolant lately?
Old Jan 4, 2006
Stachmo's Avatar
nope...I'll check it out...lol
Old Jan 4, 2006
skratch_munkey's Avatar
skratch_munkey is an unknown quantity at this point
thats normal for me but it can gets hot over here.
Old Jan 4, 2006
Stachmo's Avatar
yeah, I think its the coolant. Its about 35-40% full, so I think im gonna fill it up and see what happens
Old Jan 4, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Don't fill the overflow bottle. Fill the radiator and bleed the air out. The overflow bottle should not ever be "full" No more than half.
That pic is my normal temp. But half is save. If it goes to 3/4, you have a problem. If it goes higher, DO NOT DRIVE. You'll warp the head.
Old Jan 4, 2006
Stachmo's Avatar
what do you mean by the overflow bottle? Im going to refill the coolant and see what happens.
Old Jan 4, 2006
DDragon7's Avatar
I think he means the reservor, where the coolant goes if it overflows when its hot.
Old Jan 4, 2006
tinman's Avatar
Yep.
Old Jan 4, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
[QUOTE=tinman]Don't fill the overflow bottle. Fill the radiator and bleed the air out. QUOTE]
How do you bleed the air out?
Old Jan 5, 2006
tinman's Avatar
[QUOTE=teg91ls]
Air bubbles in the system, a common Honda problem. Porsche is even worse...
Older Hondas have a small bleeder bolt right on top of the engine next to the thermostat housing. It had a little hole in it, so you turn on the engine with the heater on high and open the bleeder until only coolant flows out. Keep adding new coolant to keep the radiator full. The D17 does not have this bleeder, the air has to work itself out through the radiator. Basically the same drill. Heater on high, open the radiator (engine cold) and top off. Start the engine and let it run until it gets warm, and/or no more bubbles come out of the radiator. Make sure it's full to the top before putting the cap back on. Also check the cap. A little crack in the rubber will make the car loose coolant slowly and get air into the system.
I should mention that IF you have air in the system, it came from somewhere. A healthy cooling system is vaccum tight. It has to be vaccum tight so that as it cools, the overflow coolant is sucked back into the radiator. So you need to look for even the smallest leak and fix it. Common leaks are the radiator cap, the heater valve, a hose, (usually a TINY bypass hose on the intake manifold) the throttle body heater, and finally a headgasket leak. All in that order.
If you bleed the system and the problem comes back.... you have a leak.
Xuhme
21
Aug 7, 2023 03:40 PM
ChristinaVHH
May 10, 2015 03:51 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
