auto tranny.
Old Dec 16, 2005
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
auto tranny.
so my tranny is slipping gears, anyway im getting it changed soon. my question, do you think its worth to swap from auto to stick?
Old Dec 16, 2005
Jrfish007's Avatar
personally, (and I'm sure some will say a stick is more fun to drive, and I would agree) I would say no it is not worth it. For the money you will spend in the conversion, you could easily spend on beefing up the auto and have a very bullit proof tranny. But that's just me, you really need to figure that one out, would you rather srive a manual?
Old Dec 16, 2005
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
How can you "beef up an auto"?
Old Dec 16, 2005
spoonJDMlX's Avatar
i jus came back from a tranny shop....the guy scanned my tranny and didnt find any codes or anything, he goes if you wna kno whats wrong with it then we have to open it up and check....makes me think, is there a rebulding kit i can buy?
Old Dec 16, 2005
streetglower's Avatar
yea you can buy the main internals of the tranny, but unless you have the tools and knowledge of an automatic tranny, I wouldnt touch it. I took apart a 41TE tranny at school, one that comes in alot of dodges and other vehicles, a plain and simple auto tranny and even that was difficult. theres alot of internals components and you need alot of special tools.
best bet, just buy a used one and have someone install it for you.
Old Dec 16, 2005
spoonJDMlX's Avatar
yeah i found a site for one
http://www.gear-speed.com/detail_trans_2.html#anchor
like an hour away from my house
Old Dec 16, 2005
Jrfish007's Avatar
Specficallyfor 7thgens.... add a cooling system.
You can also carbonize all the internal to harden them, you tighten the torque converter, adjust the shift points to make it more aggresive, make shifts harder or softer (although can be done electronically too), but you can actually do quite a bit, specially with the valve body. I've seen guys run 750 hp blown Chevy big blocks with an auto tranny, I'm guess it wasn't an ordinary tranny. But I know of a few shop that do this kind of work, here is one http://www.levelten.com/ they're pretty good from what I hear.
Old Dec 17, 2005
spoonJDMlX's Avatar
yeah i already email'd em about a rebuilding kit and a price to ship to cali.....is it true that only cali trannies are fkd up?
Old Dec 17, 2005
Jrfish007's Avatar
No, there are many all over the US I've seen on here complaining... or actually N.America, can't forget about Canada!
Old Dec 17, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
you take your car to a dealership for service? if so nothing should be wrong.
If you ever have had an outside place replace your tranny fluid.. they force new fluid in. My trannt clicks around the shifter after some bumshop force new fluid into my tranny, I compress the brake and it's gone. Get a levelten kit, I'm gonna look into that other link.
Old Dec 18, 2005
spoonJDMlX's Avatar
no way, dealer is a rip off...my guy does the same work for way less, seeing that its one of the biggest shops in LA, i get like free labor n **** (owners my dads cousin) haha....
Old Dec 18, 2005
TCI auto tranny rebuild kit
-master racing kit #559100
-auto torque converter upgrade
and you should have a solid tranny. The problem is the defective part that honda and shops know about that is weaker than it should be and accelerates wear. Also after you do those upgrades, get a tranny oil cooler.
Old Dec 18, 2005
teg91ls's Avatar
Why is your tranny slipping gears? Did you service it correctly and often enough? also did you abuse it? was it driven correctly? did u do flushes?
Old Dec 18, 2005
^ because there is a defective part from the factory that wears down the tranny faster.
Old Dec 18, 2005
teg91ls's Avatar
which part? and how much is it to replace it? and why was this not a recall?
Old Dec 18, 2005
because honda doesn't like losing millions of $ for a recall. There is an aftermarket part that replaces stock and is stronger. Most mechanics will know about it but it involves taking apart the transmission.
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
Skunkone
Sep 24, 2015 04:38 PM
