HELP!!! Gas door wont open!!!
Old Dec 11, 2005
Shifty's Avatar
Hey Everyone, as the title says, my gas door wont open and i checked the cables and everything seems in order. At first i thought it was frozen but its not...im dumb founded, this is the first time this has happened.
Im desperate since im running low on gas. Any help would be greatly appreciated!!
Old Dec 11, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
flat head screw driver and do some damage
Old Dec 11, 2005
Donggie's Avatar
Donggie is an unknown quantity at this point
Have someone push down on the lever while you use a plastic knife to pry it open.
Old Dec 11, 2005
Shifty's Avatar
I tried that first to see if it was frozen, i wrapped the flat head screw driver with cloth so i dont do "damage". Anybody else?
Old Dec 11, 2005
SlowStockCivic's Avatar
SlowStockCivic is an unknown quantity at this point
STOP!!!!! DON'T PRY ANYTHING!!!
Same thing happened to me last Thursday on my 05 civic. Turns out the linkage cable or whatever is it was messed up. I heard of this before and just went to honda. They replaced the cable in like 30 minutes under warranty. Not a common problem but it happens a lot.
Old Dec 12, 2005
Shifty's Avatar
damn eh, lucky u urs is still under warranty. Mine is a 02 and the warranty is done...lol. Good looking out man. thanks
Old Dec 12, 2005
Shifty's Avatar
i just called and the dealership is charging me $231!!! for parts and install!!!! Bullshit!!!!!!
Old Dec 12, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Move the trunk carpet and twist the cable and pull it out so you can get gas.
Then check the whole cable and see if it just came off it's guides at the lever.
Old Dec 12, 2005
Dam, that sucks. The honda tech showed me how to take out the linkage but then the problem is that your gas door won't close and you look like a dumbass driving around with the gas door opened.
See if you can buy the cable and get it installed elsewhere cuz honda charges 1.5 hours.
Old Dec 13, 2005
Shifty's Avatar
thanks everyone, i fixed it. IT was funny when i had to fill up and open my trunk to open my gas lid....lol. But i fixed it, just bent the gas lid flange a little bit and its fine. Thanks everyone.
Old Dec 13, 2005
Shifty's Avatar
oh install is no issue, i do everything on the 'vic. Dont trust anyone else, even the dealership. Anymawho its all fixed now.
Old Dec 13, 2005
Blkcivic's Avatar
yo man, mine broke too!hahaha i do it manually now
Old Dec 2, 2007
DsevenEm2's Avatar
This is Myspace
Re: HELP!!! Gas door wont open!!!
wtf man.. this just happend to me today. im bumping this up even tho its dead to see if anyone wants to help me.. exactly what do i have to do?? im on E and need sum help.. please people u know how my luck sucks with this..
Old Dec 3, 2007
01HonderCivic's Avatar
Don't be a n00b, search ftw
I just felt like calling this out....
Not common but it happens a lot. Classic!
Old Dec 6, 2007
markitect's Avatar
markitect is an unknown quantity at this point
That always makes me laugh, my 04 had this problem when it was 2 years old, so I suppose its about time again.
for DsevenEm2:
Pop the trunk and go to the side with you gas door on it. Start at the top and pull off the carpet on the side. You should find a black cylinder with a cord coming out pointing right at the gas door. Rotate it 90 degrees and it should pull out, Your gas door is open, now put the cylinder back in and rotate back. Repeat for the next month or more until you get time get it fixed or fix it yourself.
Old Dec 11, 2007
Fueldoorfix's Avatar
Former Sponsor
Fueldoorfix is an unknown quantity at this point
Go here http://www.fueldoorfix.com/tempfix.html
Download the PDF may help you see it visually?
Old Dec 22, 2007
james64's Avatar
james64 is an unknown quantity at this point
Unhappy Re: HELP!!! Gas door wont open!!!
I had the same thing happen to my 2003 Civic last year . It cost me $200. to have the entire cable replaced - Great eh ?? The mechanic told me to spray lubricant on the cable where it joins with the release lever , every time I get an oil & filter change . I have been doing that ever since and it seems to be okay . Good Luck !!
Old Dec 22, 2007
LatinEM2's Avatar
LatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of light
What if your trunk won't close!! My cable broke today, and I need a way to close the trunk. The gas door and trunk cable are the same right? I just need a way to close my trunk ??!
Here's a pic:
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
werdnahall
May 17, 2015 11:37 AM
darwin-t
Apr 18, 2015 09:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
