Grounding With Kit I bought of Ebay
Old Dec 6, 2005
sao33's Avatar
sao33 is an unknown quantity at this point
Hey Guys,
I was wondering if anybody has any instructions on how to install this grounding Kit i got off ebay.
ebay item 8014133422
(sorry can't post links yet still new)
I'm sure it's realtivly simple, but if someone has some pics, and instrutions on how to set it up please let me know.
Thanks Guys!
Sao
Old Dec 7, 2005
http://www.7thgencivic.com/forums/sh...t=ground+wires
Old Dec 8, 2005
grapehead's Avatar
grapehead is an unknown quantity at this point
i got a similar kit off ebay, ran them to:
transmission
core support
throttle body
valve cover stud
tstat housing
fenderwell where the stock one was
Old Dec 9, 2005
sao33's Avatar
Do you have pictures of where I can ground them on those parts?
If so send them to me at at sao@tith.net
Thanks
Sao
Old Dec 9, 2005
there is no reason to send grounds everywhere and it could actually be worse in causing ground loops. Replace the factory points only.
Old Dec 9, 2005
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
what is the kit suppose to do
Old Dec 9, 2005
the stock ground wires are very small and often get corroded or damaged. Upgrading them with thicker wire can improve current flow throughout the car's electrical system. can reduce dimming and sometimes make certain parts work better.
Old Dec 9, 2005
DAQIUN's Avatar
good to here
Old Dec 22, 2005
DTTheEmperor's Avatar
DTTheEmperor is an unknown quantity at this point
Well I just order a kit for my car and I was wondering did you notice any difference in performance when you upgrade your ground wires from the stock?
Old Dec 26, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Me personally I did not notice any true performance upgrade as a result of the new grounding kit. I don't know if it was just my imagination, but it did feel that there wasn't so much of a lag but I don't know. It might have been that things just weren't as noticible as other mods.
Old Dec 26, 2005
no real difference, just assurance that you're getting the most out of your electrical accessories. the older accords actually use a 4 gauge ground wire stock.
Old Dec 26, 2005
blouisgod's Avatar
Life Begins > 6800rpms
werd, youll notice too that your headlights wont dim (or as much) if you have a sub and amp combo.
Old Dec 26, 2005
one thing that will help is an upgraded headlight harness. it gives the bulbs a couple more volts that crap factory wiring robs. i have stock philips bulbs and they are noticably whiter that other stock cars on the road.
Old Jan 3, 2006
mclean987's Avatar
mclean987 is an unknown quantity at this point
i just wanna know is it better to replace wires or leave stock wires and put new wires aswell
Old Jan 3, 2006
only replace the stock wires and don't run any new ones.
Old Jan 4, 2006
mclean987's Avatar
what you mean i have central grounding poinbt for battery so dont run the wires from that to intake, valve cover, tranny, alternator, radiator or supoort front bumper and other points ? got 7 wires whats the best points to ground
GolNat
Suspension DIY
May 12, 2022 06:49 AM
KillerX
Apr 9, 2017 08:20 AM
mistermenphis22
Apr 3, 2016 08:06 AM
zaboomafoozarg
May 30, 2015 09:21 AM
beveragemp
May 25, 2015 07:11 PM
