Anyone here done a o2 sensor yet?
Old Nov 22, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Exclamation Anyone here done a o2 sensor yet?
Did a little searching, mostly found o2 sims.
I'm throwing codes on and off for PO133 slow sensor response bank 1 sensor 1. Has anyone here done one have a good place to buy, prices, diy?
Thanks, wanna do this as soon as possible seeing as it's my primary sensor.
01" EX
Old Nov 22, 2005
igetmadchocha's Avatar
igetmadchocha is an unknown quantity at this point
never heard of it
Old Nov 23, 2005
tacheon's Avatar
tacheon is on a distinguished road
01" EX
I've done them on a few other vehicles. Get yourself an oxygen sensor socket. It's basically a deep socket with a notch in the side to allow the harness to go through it. You can buy an oxygen sensor from anywhere which sells car parts along with the socket. It's as easy as changing a spark plug. Just unplug harness, and remove the oxygen sensor. Installation is same as removal. If it doesn't turn with a moderate amount of force, use a penetrating lubricant, wait an hour, and try again. Forcing it out will result in a stripped threads.
Old Nov 23, 2005
Jrfish007's Avatar
Yeah, it's fairly simple to get do, getting it turn is a bit of a pain though. Use some PB Blast, spray and let it set for a couple of hour try agian and just keep spraying it down until it turns. I presonally just use a wrench, but I have not done it on a 7thgen, so maybe there is not enough room for that.
Old Nov 23, 2005
Thanks guys, good advise. Anyone esle have info on it. I can't believe more people on here havent done them yet, there many cars on here with 100,000 m + on them!
Old Nov 23, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
yes ... get an o2 sensor socket ... chances are that you will strip it ... and they're very easy to strip.
Old Nov 23, 2005
djmota's Avatar
part number 18 40.00 bux plus shipping oem honda. a proper sized wrench will work fine do not use an adjustable. If you have problems getting it off run the car around the block and try it while its hot.
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
Old Nov 23, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
yea its fairly easy to get off. me and my friend used wd-40 to get it off and it didnt strip cause we got it bak on easily. my secondary o2 is given the same thing as yours. gettin it replaced soon
Old Nov 23, 2005
Jrfish007's Avatar
yeah, but don't use WD-40 when it's hot.
Old Nov 28, 2005
Good info guys, thanks. It should be easy, hey were not working on 89 CRX ya know! ha ha
Old Nov 28, 2005
Rufus's Avatar
I used a wrench. I have a SIM on the car
Old Dec 1, 2005
A SIM is fine for SECONDARY sensor, but not primary. I think that the car would run better with both, unless you have no cat.
The light is going on and off, few days on, few days off, what up with that?
Old Feb 22, 2006
Bump!
Old Feb 22, 2006
streetglower's Avatar
Have you replaced the sensor yet?
Old Feb 23, 2006
Nope light still going on and off, few days on few off, cars drives normal.
Old Jul 18, 2006
Boods's Avatar
Boods is an unknown quantity at this point
My car was doing exactly what ur car is doing... then the light stayed on, and now im getting hit with an $800 CAN repair bill for various plugs and injectors and the like, as well as an O2 sensor.
im not sure if its stuff i could do myself or not... id love to do it tho.
Old Jul 18, 2006
s13_240sx_92's Avatar
s13_240sx_92 is an unknown quantity at this point
This is why I love this forum.
Originally Posted by igetmadchocha
never heard of it
Its an easy install. Yes get the socket and becareful not to strip the o2 nut.
You might be able to just remove the old o2 sensor and clean it off using a propane torch to burn off the crap that may have accumlated on it.
Good luck.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
