I need some opinions!!! SWAP / DIY
Old Nov 14, 2005
tweeder's Avatar
tweeder will become famous soon enough
Question I need some opinions!!! SWAP / DIY
I have a 01 ex. I want to swap the a1 block in keeping the a2 head. Mild PnP and weld in a d16 or b18 intake manifold.
1st Am i going to have any problems dropping that block (a1) into an ex (ecu or vtec, maybe).
2nd Will I gain any power by getting rid of the egr and gaining some compression (I think) using this block (a1)
I got a complete a1 engine for $183 with about 27,000 miles on it, so I couldn't pass it up!
And I will end up doing a complete diy for everyone with the IM swap.
Any ideas, or comments are welcome if not demanded!
Old Nov 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
370647 001 BLOCK ASSY., CYLINDER (DOT) = vtec and non-vtec so the block wont effect compression ratio at all and is interchangeable
#2 possibly, but you will need to figure out a way to trick the ecu that its not there
as far as it changing compression ratio....only the pistons/cyl head will effect compression ratio, and please do a DIY on the intake manifold if you can i think lots would enjoy it
Old Nov 15, 2005
tweeder's Avatar
Thanks! so how does egr work anyway and what sensors are used / need to bypass?
SidCivic
17
Aug 23, 2015 03:14 AM
OldschoolCool
Aug 17, 2015 05:05 PM
henrytn
Aug 11, 2015 10:01 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
